General Information
Year
1996
Make
Ford
Model
Mustang GT
• Stage 3 AMG cylinder heads
• Comp valve springs
• 102500 Comp Blower Cams 242 intake 238 exhaust @50 112 lobe separation with .550 lift
• ARP head studs
• Cometic head gaskets
• 8.5:1 Probe forged pistons
• Scat H-beam rods
• Forged oiling modified crankshaft
• Mahle file fit rings
• Modified SVO high volume oil pump
• Moroso 8 quart oil pan
• ATI Procharger D-1SC Intercooled Supercharger System
• 60lb Injectors
• BBK Long Tube Headers
• Magna Flow X-Pipe with high flow Cats and Magna Flow Mufflers
• Custom ECM Programming
• Anderson Power Pipe
• Trick Flow Track Heat Intake manifold
• New Tremec TKO-600 HD 5speed Transmission with Ripper Shifter Centerforce Clutch and Flywheel
• Scattershield
• 3.73 HD Gears with new Posi Unit
• 31 spline axles and new bearings
• Brembo Disc Brake Upgrade All around
• Camber Kit
• Steeda Full LengthSubframe Connectors
• Tokico Adjustable Shocks and Struts
• Steeda Adjustable Tubular Control Arms
• Steeda Heavy Duty Sway Bars front and rear
• Steeda Heavy Duty Coil Springs
• Aluminum Radiator with Hi-flow dual electric fans
• Boost and Fuel Pressure Gauges
• WolfeCraft Racing 6pt Rollcage
• Corbeau LG1 Full Micro-Suede Racing Seats with 4-point Harness
• Rear Seat Delete
• New carpet
• Twin Nitrous Express 10 lbs Bottles
• ARP head studs
• Scat H-beam rods
• 60lb Injectors
• Scattershield
• Camber Kit
• Rear Seat Delete
• New carpet
