General Information
Year
1989
Make
Ford
Model
Mustang LX
306 Eagle rotating assembly with Trick Flow Twisted Wedge aluminum heads. Trick Flow Track Heat upper and lower intake with 1" spacer. Summit Racing 75mm throttle body and EGR delete block. Vortech V-1 T- trim super charger set to 8lbs of boost. Airflow 75mm MAF and sample tube. A/C and smog delete. Proform electric water pump. 3 core aluminum radiator with 2 small and 1 big electric fans. Vortech T-Rex 255 fuel pump and FMU to feed the adjustable FPR and 30 lb injectors. Tremec TKO 600 5 spd and King Cobra clutch that goes through an aluminum driveshaft feeding the 8.8 with 4:10 and Auburn posi unit to get the power to the ground. 26" MT ET Streets out back with skinnys up front on Weld Draglites. Eibach Sportline lowering springs and rear control arms. Full interior with 6 point cage and racing seats in front and still has console.
Comments
There are no comments to display.
