General Information
Year
2002
Make
Ford
Model
Mustang GT
Engine mods...
Procharger P1SC 9~10psi
AFM PowerPipe
3 Core Intercooler
42lb Injectors
NGK TR6 Plugs
255LPH Focus Fuel Pump
Diablosport Chip Custom Dyno Tuned
90MM Lightning MAF
BBK 75mm Throttle Body
Trick Flow Intake Plenum
Ported Tyhpoon Intake
Canton Oil Pan w/Windage Tray
BBK Long tubes with Catted X Pipe
MagnaFlow Catback
Polyurethane Motor Mounts
Canton Aluminum Coolant Tank
MSD 2Step
Drivetrain mods...
Promotion Built 3650 w/ 26spline Input
Steeda Tri-Ax Short Shifter
Centerforce DFX Clutch
Spec Billet Flywheel
Steeda Adjustable Quadrant/Firewall Adjuster
Moser 31 Spline Axles
Ford 31 Spline Diff w/ Carbon Clutches
Ford Racing 3.73 Gears
TrickFlow Diff Cover
Welded Axle Tubes and Torque Boxes
Ford Racing Aluminum Driveshaft With Saftey Loop
Suspension etc...
Steeda Alum. Upper & Lower Control Arms
Steeda Competition Springs
Steeda Front Sway bar
Steeda Adjustable Rear Sway Bar
Steeda Full Length Subframe Connectors
Steeda 3bolt Caster/Camber plates
Steeda X2 Balljoints and Bumpsteer kit
Tokico 5 Way adjustable Shocks
Racecraft K Member
Cobra Calipers With Drilled/Slotted Rotors
Stainless brake lines
Polyurethane A Arm Bushings
Snow Performance Strut Brace
18x10in Rear Rims w/ 295's
15in Weld Prostar Drag Big n Littles
Battery Relocation w/ Kill Switch
Other Stuff..
Corbeau CR1 Microsuede seats
AutoMeter Lunar Series Gauge Cluster
Autometer Lunar series Boost and Fuel Press. Gauges
Raptor Shift Light
Removed GT Badges
Roush Stage 3 Bumper
Cobra Mirrors
Sequential Tail Lights
12.3 @112mph 1.8 60ft 5200ft elevation
AFM PowerPipe
3 Core Intercooler
42lb Injectors
NGK TR6 Plugs
90MM Lightning MAF
MagnaFlow Catback
MSD 2Step
Drivetrain mods...
Suspension etc...
Racecraft K Member
Other Stuff..
Raptor Shift Light
Removed GT Badges
Cobra Mirrors
