General Information
Year
2005
Make
Mustang
Model
GT Coupe
ENGINE
FRPP 3v Intake Manifold
Comp Cams Stage 4 Cams
FRPP Throttle Body
1” Throttlebody Spacer
Comp TurboCT4-6765 -Description: CT4-6765 Journal Bearing Turbocharger, ported anti-surge compressor cover (4″ inlet, 2.5″ outlet) with a 67mm Billet Compressor wheel. HE65mm 10 blade high efficiency Turbine wheel and a .81 T4 undivided 3″ V band turbine housing.
PMAS HPX maf sensor
BOV
38mm Wastegate
Miscellany
Cobalt, Oil Pressure, Wideband and Boost gauges
Steeda UD pullies
Axel Exchange 1 Piece lightweight driveshaft
Driveshaft loops
Hurst Shifter
Suspension:
BMR K-Member
Steeda Lightwieght radiator support
UPR Lower control arms
UPR adjustable panhard bar
BMR Panhard bar brace
Edelbrock Upper control arm and mount
Steeda Competition Springs,
Tokico D-Specs
J&M Camber plates
FUEL
80lb/hr FRPP Injectors
405lph Walbro Fuel Pump
Scott Drake Fuel Rails
Fuel Pump Wiring upgrade
Brakes
Brembo brake upgrade w/slotted dimpled rotors, race pads, stainless steel brakelines
EXHAUST:
FRPP Cat Back (Borla Stingers)
Mac Shorty Headers
Gears: 3.27s
Appearance
Steeda Front Splitter
Steeda Race Wing
Tinted windows
Eleanore style grill
FRPP Throttle Body
PMAS HPX maf sensor
BOV
38mm Wastegate
Miscellany
Steeda UD pullies
Driveshaft loops
Hurst Shifter
Suspension:
BMR K-Member
Tokico D-Specs
J&M Camber plates
FUEL
Brakes
EXHAUST:
Mac Shorty Headers
Gears: 3.27s
Appearance
Steeda Race Wing
Tinted windows
