General Information
Year
2002
Make
Chevrolet
Model
Camaro SS
2002 Camaro SS A4 Sunset Orange Metallic
-Lingenfelter CNC heads
-Thunder Racing 224/[email protected] lsa
-Pacesetter longtubes
-3" cat less exhaust
-Built 4l60e with 3.73 gears and 3300 stall
2002 Camaro SS M6 Light Pewter Metallic. RIP 11/21/12
- Full 3" exhaust from Texas Speed and Performance
- SLP Hi-Flow Cats
- Skip Shift eliminator
- Bilstein Shocks
- Eibach Pro-kit
2002 Camaro SS M6 Onyx Black......Sold
-BMR Adjustable Lower Control Arms
-Wilwood Drilled/Slotted Disc brakes/Pads
-Adjustable Pan Hard bar
-Detroit Trutrac differential
-Dana s60 rear
-Strange Axles w/ extended wheel studs
-Turbo Technology Inc. Turbonetics T76 7.5lbs boost
-50# Seimens injectors
-340lb walbro fuel pump
-BMR Engine Sway bar
-BMR Sub frame Connectors
-Spohn Driveshaft loop
-Pro 5.0 Shifter
-Cut out
-Hooker Exhaust
-Custom Driveshaft
- SLP Hi-Flow Cats
- Bilstein Shocks
- Eibach Pro-kit
-Dana s60 rear
-Pro 5.0 Shifter
-Cut out
-Hooker Exhaust
-Custom Driveshaft
