General Information
Year
2001
Make
Mustang
Model
GT
Mods
Apperance:
Custom Two tone paint
03 cobra front bumper
shaved decklid
18 black DD bullits
Suspension:
Eibach springs
Kennybrown welded in full lenght subframe connectors
BMR lower controll arms
steeda bump steer kit
Energy prourathane endlinks
Cobra brakes, with slotted and dimpled rotors
Goodrich SS braided brake lines
Hawk pads
Engine mods:
MMR 900 long block
03 cobra crank
Manley H beam rods
Daimond pistons
ARP hardware all the way around
Dragon 75mm TB and plenum
42lb injectors
90mm LMAF
Vortech V2 S-Trim
Aftercooler
Afco heat exchanger
MPH boostpipe
Stratmosphre Bypass valve
Mac ceramic coated long tubes
Off road h pipe
MRT cat back
Stage 8 locking header bolts
MSD coil packs
NGK TR-6 plugs
Spec stage 2+ clutch
Fidanza Light weight flywheel
And Ect.
Apperance:
shaved decklid
18 black DD bullits
Suspension:
Eibach springs
Hawk pads
Engine mods:
MMR 900 long block
03 cobra crank
Manley H beam rods
Daimond pistons
42lb injectors
90mm LMAF
Vortech V2 S-Trim
Aftercooler
Afco heat exchanger
MPH boostpipe
Off road h pipe
MRT cat back
MSD coil packs
NGK TR-6 plugs
And Ect.
