General Information
Year
2000
Make
ford
Model
black mustang gt 2v 4.6
all new block,heads,cams,t-trim and some. 500hp to the rear with a boost pump should be in the 600 plus hp to the rear
ENGINE:
v1 s/c,
intercooler,
anderson power pipe,
big 4" k&n air fliter,
8 rib pulley & belt setup,
vortech racing blow off valve,
new 4.6 2v short block,
accufab combo 70mm,
ngk s.p.,
42lb injecters,
gns coil packs,
walbro 255 pump,
160 t-stat,
fluidyne aluminum radiator,
canton aluminum expansion overflow tank,
canton aluminum power steering tank,
steeda oil separator kit,
tyhroon intake manifold,
90mm mass air,
snow kit,
sct xcal2 dyno tune,
zitoronics wide band,
200amp alternator,
bbk chrome valve covers,
custom braided lines,
upr engine dress up kit,
mac long tube header,
bassani off road xpipe,
steeda muffler & tail pipe,
kinetik hc1800 battery (moved to the back of the car)
DRIVETRAIN & BRAKES:
rear 373's,
frpp aluminum driveshaft,
rear axles,
tr3650 trans,
king cobra,
lakewood driveshaft loop,
steeda tri-ax shifter,
cobra brake kit 13" fronts & 13" rear, rotors drill & slotted
ford racing 8.8" axle girdle
SUSPENSION:
steeda rear uppers & lowers,
steeda bumpsteer kit,
steeda x2 ball joints,
steeda front & rear sway bars,
kyb shocks & struts,
coilover in front,
eibach pro kit in back,
mm caster-camber kit,
bbk strut tower brace,
frpp sub frames,
tubular k-member,
front control arms,
AUDIO:
custom (fab) fiberglass trunk,
17" tv (fab) into the bottom of the trunk lid with two 6"rf speakers
10" alpine subs woofers,
alpine woofers & tweeters,
alpine flip out face head unit,
amps are alpine,
pc, rf 360,
BODY & EXTERIOR:
new paint,
saleen style body kit,
saleen speedter cover,
mach1 hood,
redline hood struts
shaved door handles,
shaved badges,
shaved antenna,
door poppers
custom cut billit in the front & rear bumpers,
cobra side mirrors,
saleen style rims 18",10 & 18", 9,
blue hids with chrome headlight,
blue light kit in the rims & under carriage,
rear camera in the rear trunk latch,
INTERIOR:
autometer gauges,
custom seat's,
k-40 build in radar,
viper alarm,
fr 500 steering wheel,
custom made three gauge a-piller,
dual gauge a-pod,
roush gauge cluster,
upr billet interior package,
white face a/c control panel,
new plush rug,
ENGINE:
v1 s/c,
intercooler,
accufab combo 70mm,
ngk s.p.,
42lb injecters,
gns coil packs,
walbro 255 pump,
160 t-stat,
90mm mass air,
snow kit,
200amp alternator,
rear 373's,
rear axles,
tr3650 trans,
king cobra,
SUSPENSION:
coilover in front,
frpp sub frames,
tubular k-member,
front control arms,
AUDIO:
amps are alpine,
pc, rf 360,
BODY & EXTERIOR:
new paint,
mach1 hood,
redline hood struts
shaved badges,
shaved antenna,
door poppers
cobra side mirrors,
INTERIOR:
autometer gauges,
custom seat's,
viper alarm,
dual gauge a-pod,
new plush rug,
