Showcase cover image for Money Pit
General Information
Year
2003
Make
Ford
Model
Mustang
Color
Sonic Blue
Packages
Whatver they were, they are gone now
History
Purchased by moron from sheisty F%%k who lied and hid a series of problems that prevented the moron from smogging the car and eventually ending in the motor melted (both unrelated). Moron then purchased parts car for the Money Pit and swapped in a new motor and everything missing that Sheisty salesman lied and said was there. Moron has now dumped loads of time, money, and blood into this car and is happy as a clam.
2003 Ford Mustang (Sonic Blue)
Modifications
Drivetrain
4.6 Sohc w/ Vortech V2 3.33, treadstone IC, BBK 78 TB, Custom power pipe, 38lbs injectors.
Exterior
95 Cobra R Style Hood
SVE 03 Cobra Wheels
Mach 1 Chin Spoiler
Audio
Built sra, Eaton Posi, Moser 31 spline, 3.73s, Steeda short shifter.
Suspension
Willwood 13" Big Brake Kit, Front and Rear
Max Motorsports "Max Grip Box"
.MM K-member (with 2-point brace)
MM Front Control Arms
MM Torque-arm
MM Panhard Bar
MM XL Series Full-length Subframe Connectors
MM Coil-over Conversion Kits, Front and Rear
Coil-over springs
MM Caster/Camber Plates
MM HD Rear Lower Control Arms
Koni SA shocks
MM Adjustable Rear Swaybar
MM Aluminum Steering rack Bushings
MM Solid Steering Shaft
MM Bumpsteer Kit (adjustable outer tie-rod ends)
MM Strut Tower Brace
MM Front Swaybar Relocation Kit
Front Swaybar Bushings
Front Swaybar End Links
(List copied and pasted from MM website because lazy)
Wheel and Tire
Staggered 9 and 10.5 Nitto 555s, moving to a non staggered setup for road course racing.
Gallery
Comments
There are no comments to display.
