Showcase cover image for Mooney's 1998 Ford Cobra
General Information
Year
1998
Make
Ford
Model
Cobra
Engine: Ported Stock Upper/Lower Intake Manifolds - Ported Stock Throttle Body - Vortech V1 T-trim (3.3 inch and 3.6 inch Pulleys) - Paxton Air-to-Air Intercooler - Braided Oil Feed Line - T-Bolt Clamps - High Temperature Silicone Couplers - Custom 4 inch Power Pipe - 12 inch Air Filter - Custom Discharge Plumbing - Pro-M ATI Blow-Thru Meter - Vortech Mini Race By-Pass (X2) - Fluidyne Radiator - Custom Boost Sensitive Electric EVAC System w/ Oil Catch-Can and 12an Lines - IAC w/ an -10 Braided Hard Line to Discharge - Kenne Bell Boost-a-Spark - Taylor 409 Pro-Race Plug Wires - Autolite AR103 spark plugs - SCT 4-Bank Chip (Valet/Bodyshop Tune and 91 octane w/ 11.3 A/F Ratio Tune)
Fuel System: Aviator Fuel pump - FMS 42 # Injectors - Aeromotive Fuel PSI Regulator
Exhaust: BBK Longtube Headers - BBK Shorty H-pipe - Flowmaster American Thunder Catback - Brothers Performance MIL Eliminators - Brothers Performance Oxygen Sensor Extension Harnesses
Suspension and Drivetrain: FRPP Aluminum Drive Shaft - Maximum Motorsports Panhard bar - Maximum Motorsports Adjustable Lower Control Arms - Maximum Motorsports Full Length Subframes - Maximum Motorsports Swaybar End Links - Maximum Motorsports Strut Tower Brace - Koni Yellow Struts and Shocks - Griggs Coilovers (front) - Griggs 350 # Coil Springs (front) - Griggs 300 # Conventional Springs (back) - Griggs Caster/Camber Plates - Griggs Bump-steer Kit - Griggs Solid Rack Bushing - Rear T/A Performance Girdle - Welded Battle boxes (lower control arms - rear) - Spec Stage III Clutch - UPR Clutch Quadrant - UPR Extreme Firewall Adjuster - FMS Clutch Cable - Rear ARP Wheel Studs - FMS 4.10s
Wheels and Tires: 17X9 Chrome Cobra R's on 265/40 Toyo T1's (front) - 17x10.5 Chrome Cobra R's on 315/35 Nitto Drag Radials (back) - 3/4 inch Wheel Spacers (back) - Gorilla Locking Lug Nuts
Interior: MGW Shifter - Fatknob Shift Handle - Autometer A-Pillar Pod - Autometer Gauge Cluster Bezel Pod - Autometer Phantom Wideband Air/Fuel Meter (X2) - Autometer Phantom Boost/Vacuum Gauge - Autometer Phantom Fuel PSI Gauge - Autometer Phantom Coolant Temperature Gauge - Custom Low Oil PSI Light (mounted in A-Pillar Pod)
Gallery
Comments
There are no comments to display.
