General Information
Year
01
Make
Ford
Model
Mustang V6
Management:
Diablo Predator tuned by Abel Racing
Engine:
Head Studs
Forged .020" over 10.5:1 Flat-tops
224/230 .550 SSMS Cam
Longer Hardened pushrods
1.7 Roller Rockers
Matched/Machined/3-angle Heads milled .030"
LS6 yellow Springs w/ GT retainers
Stock sized flat faced valves
P&P Lower intake
Windstar swap
GT 65mm port matched Throttle Body
Motoblue 42% UDP
24# Injectors
90mm MAF
PCV oil catch can
EGR removed
Exhaust:
Pacesetter ceramic coated longtubes
Catless
X-pipe
40s dumped
Trans:
Rebuilt trans
Tri-AX
Ram HDX clutch
Spec steel flywheel
Steeda Quadrant
Steeda Cable
Rearend:
SN95 8.8
FRPP Carbon clutch kit
FRPP 4.10s
Suspension/Body:
UPR Standard length sub frame connectors
MM Solid rack bushings
MM C&C plates
UPR Tubular rear upper and lowers
Bumpsteer kit
GT rear sway bar
Quad shocks
UPR Coilovers Front (12-200) & Rear (10-150)
Strange 10-way Struts/shocks
Brakes:
Cobra Front Brakes
Ceramic pads
Slotted/Drilled rotors
SLP Line lock
Dot 4
Other Stuff:
Mach 1 Front goodies
Battery in trunk
Red LEDs under dash
Spoiler removed
GT wheels
LEDs in gauges
7 ball shifter
LEDs In trunk
Comments
There are no comments to display.
