General Information
Year
2000
Make
Ford
Model
Mustang GT
~Motor, Induction, Igition, & Electronics~
D.S.S. Racing Forged level 9 Bottom End 4.6 2-V (9.5:1 Compression)
Patroit Stage 2 Heads
ARP Head Studs
Comp Cams XE274 cams
Prof. Products Intake
Accufab 75mm TB and Plenum
Grantelli Coils
ZEX Plugs
Grantelli MAF and housing 77mm with C&L intake tube
Hypertech 160 Degree Thermostat
SCT tuner
Trick Flow Valve Covers
Jesel Cam Followers
Moroso Deep Sump Oil Pan
Steeda Underdrive Pulleys
Canton Overflow Tank
~Fuel system~
Areomotive Eliminator Regulated Fuel System and Fuel Rails
FRPP 24 lbs injectors
~Tranny~
TCI Internals and Valvebody
TCI Deep Sump Pan
TCI 2500 RPM Stall
~Rear End~
Stock Trac-Loc
FRPP 3.73 Gear
Grantelli Inspection Cover
~Suspension~
Grantelli Front Suspension K-Member, A-arms, and Coil-overs
Metco LCA
Metco Adjustable UCA
BBK Sub-Frame Connectors
Drag Launch Springs in the Rear
~Brakes & Steering~
Flaming River Manual Rack & Pinion
Brembo 4-piston Brake Upgrade with rotors
Maximum Motorsports Manual Brake conversion
~Exhaust~
Pacesetter Long-tube Headers
Flowtech Header Cutouts
Mac O/R 2.5 inch Pro-Chamber
Flowmaster Super 40 2.5 inch Cat-back
~Misc.~
Dual Battery Recloate to trunk
Autometer Guages
UPR Cluster Face
Chrome Mach 1 18's
01 Cobra Hood
Mach 1 Chin Spoiler
Mach 1 Grille Delete
ARP Head Studs
Grantelli Coils
ZEX Plugs
SCT tuner
Jesel Cam Followers
~Fuel system~
~Tranny~
TCI Deep Sump Pan
TCI 2500 RPM Stall
~Rear End~
Stock Trac-Loc
FRPP 3.73 Gear
~Suspension~
Metco LCA
~Brakes & Steering~
~Exhaust~
~Misc.~
Autometer Guages
UPR Cluster Face
Chrome Mach 1 18's
01 Cobra Hood
Mach 1 Chin Spoiler
