General Information
Year
1994
Make
Ford
Model
Mustang GT coupe
Built 347 AMP performance short block- all forged internals, AFR 185 aluminum cylinder heads- 202 intake and 160 exhaust valves, ARP studs, 1.6 roller rockers, Trick Flow stage 2 cam, Trick Flow upper amd lower intake with 94-95 adapter, Trick Flow valve covers, Milidon dual sump oil pan, FRPP 30 lbs injectors, PMAS 75mm MAF, MAC cold air kit, BBK 70mm throttle body, MAC equal length shorty headers, Mac off road h-pipe, Mac catback kit with stainless tips, FRPP 3.73 gears, Built 4R70W trans, Nitto NT 555R- 275/40 R17 drag radials, and finally....200 hp Nitrous Works wet kit. SCT tuned by Pro Dyno- Fort Mill, SC- Thanks Rob and Dan! Too many other mods to list. No times with this set up. Old times with stock motor was 14.20 @ 95mph- all motor and 13.04 @ 104 mph on 100 shot of giggle gas.
