Showcase cover image for NickPohlAandP's 2000 Ford Mustang GT
General Information
Year
2000
Make
Ford
Model
Mustang GT
Exterior:
18x9 Bullitt wheels
Nitto 555 255/35-18 front
Nitto 555 285/40-18 rear
Tint that has to be illegal (installed by PO)
New top installed August 2012
Interior:
Stock black leather
2 gauge pod insert for instrument panel with AEM wideband and Oil Press.
Engine/Powermakers:
MMR 4.75 750se 9.5:1 compression
Trick Flow cylinder heads
Trick Flow Stage 2 cams
COMP adjustable cam gears (safety wired)
Steeda UDP's
Trick Flow CAI
BBK 75mm TB
C&L plenum
60 lb injectors
Division X 340lph fuel pump
BBK shorty equal length headers
BBK catless X pipe
MAC Prochamber
Tuned with Special Forces Commando
Chassis/Drivetrain:
UPR chrome moly K member
Coil over struts 200lb springs
Strange 10 way adjustable struts
Steeda bumpsteer kit
CC plates
Full poly bushing front end
Global West tubular FLSFC's
Tubular chrome moly upper and lower rear control arms
Poly bushings on both ends of the lowers
Poly bushings on vehicle side of uppers
Drag bag, helper air bag in right rear spring
T45 trans with Tri-Ax shifter
8.8 rear with 3.37's
Drake rear end girdle
Gallery
Comments
