General Information
Year
89
Make
Ford
Model
Mustang
398 [email protected] RPM
501 lb [email protected] RPM
Esslinger SVO Head, fully ported.
Esslinger 2.7L crank.
Eaton TVS 1900 [email protected] PSI boost.
Cometic head gasket.
Custom cam/re-ground .515" lift Int .535" lift Ex 278/282 duration
Speedflow header
Bosch E53E-9F593-AB injectors
3"-2.5" exhaust
Intercooled intake manifold & front mounted IC.
CP pistons 8.9:1 C/R
TRW rings
Clevite bearings
Bronze distributor gear
Esslinger widage tray
Crower rods with ARP bolts
MSD 6AL with timing control Unit is typically broken!
Shiftmasters EEC tuner
A4LD 4.0L transmission with a 2.3 bell housing bolted to it + Transgo Shift Kit, double clutch 4 liter torque converter, large servos for 2nd and overdrive, oversize pressure boost valve.
Has a broad torque curve from 2500-6800 RPM
Needs to run water injection to make max power.
It was definitely worth the effort.
When I stay off the gas, it will average 21 MPG
Speedflow header
3"-2.5" exhaust
TRW rings
Clevite bearings
