General Information
Year
1998
Make
Ford
Model
Mustang
Blue with black/Charcoal Interior. Tinted Windows. Custom Stereo System, Pioneer 5x7 in front, Audio pipe 6x8 in rear, powered by Pyle Chopper series Amp, Pioneer 12's powered by Bazooka Amp. The interior of this car is in excellent shape. I have personally changed the oil (Castrol GTX 10w30) every 3 months or 3000 miles, which ever occurs first. I have changed the fuel filter ( K&N) every 10,000 miles. I use sea foam before every oil change. Motor is extemely clean!!! Due to head swap engine compression is 11:1 ( permium gasoline only!!) . The car runs and drives perfectly. very quick!
SCT 2 6600 series 4 bank eliminater chip w/ switch cable
99 GT Performance Heads
99 GT performance Intake
99 GT cams
24# injectors
255lph walboro racing fuel pump
Steeda underdrive pully
Steeda Auto-timing adjuster
Pro-M 87mm MAF
K&N air filter
Optima Red top High performance battery w/ Gold stinger terminals
Bosch platinum +4 plugs,
Brendel racing 8mm sparkplug wires
Steeda K- member
Steeda strut tower brace,
Steeda full length welded sub frame connecters
Steeda bumpstear
Maximum Motorsport caster/camber,
Maximum Motorsport front and rear sway bars
Steeda coil overs in front with steeda pro springs
Steeda offset bushings
40 series flowmaster mufflers
MAC 2 1/2 inch off road h-pipe
Tokico Illumina 5 way adjustable shocks/struts (front and rear)
Eibach sportline springs in rear
Steeda X2 ball joints
Steeda Adjustable rear lower control arms
Steeda G-trac bar,
Steeda tri-axe short throw shifter
3:73 Gears
Cobra replica headlight kit w/ Clear Corners
Sylvania "white light" headlamps
Steeda brushed aluminum door sill plates
Hawk performance racing brake pads
Tr Motorsport Typhoon Rims( 18x9 in front, 18x10 in rear)
99 GT cams
24# injectors
Pro-M 87mm MAF
K&N air filter
Steeda K- member
Steeda bumpstear
Steeda G-trac bar,
3:73 Gears
