General Information
Year
1989
Make
ford
Model
mustang lx
It has a stock 302 bottom end and has not been touched except for the O-ring and lock-wires. I went with Edelbrock heads (1.90/1.60) and Edelbrock RPM intake, 30# injectors, 70 mm throttlebody, 73 mm mass air meter, Blue racer cam .510/.534 lift w/1.70 roller rockers, 1 5/8 full length headers and 3" exhaust, crane ignition and coil.
Still has stock suspension and 4:10 gears. It ran 11.91 @ 124 with that set-up except it had the E303 cam (.498/.498)and stock transmission(and had a power dyne super charger 11 psi.). Since then I added PMS (programmable management system), Mr. Freeze (windshield wiper fluid injection from Anderson Ford), and a Art Carr aod w/ 10" converter 3500 stall. I am now installing twin turbos and I'm about 1/2 way done.
