General Information
Year
1999
Make
Ford
Model
Cobra Mustang
99 Cobra Vert - Red/Blk/Tan
Built Engine by HCI in Sac
-.30 over bore = now 288 cu in
-Forged CP Flat Tops
-Forged Manley Rods
-Balanced
-Ported & Polished Heads
-Cams
-30lb injectors
-Morpheus Pipe
-ProM 80mm MAF
-Bassani Mid-Length Hdrs
-Bassani X & Catback
-Meziere Electric Water Pump
-Steeda Timing Adjuster & Pullies
Full Griggs suspension GR40
-tubular top & bottom
-Koni Coils at the corners
-Frame connectors
3.73 gears
Aluminum Drive Shaft
Tri-Ax shifter
Roush Wheels
-Forged Manley Rods
-Balanced
-Cams
-30lb injectors
-Morpheus Pipe
-ProM 80mm MAF
-Frame connectors
3.73 gears
Tri-Ax shifter
Roush Wheels
