Showcase cover image for Reef Blue's 1993 Ford Mustang LX 5.0
General Information
Year
1993
Make
Ford
Model
Mustang LX 5.0
1993 Reef Blue Mustang 5.0 LX Hatchback 331ci Balanced/Blueprinted Forged Internals with windage tray and Canton 7qt pan. Vortech Blower and Aftercooler and Twisted Wedge CNC Factory Ported Heads Comp Cams Blower Cam Holley Systemax FI Intake Anderson Power Pipe Pro-M #88 Mass Air with Accufab 70mm TB. 42lb injectors. Aeromotive A1000 Fuel Pump and 12 gallon sump tank MSD 6AL/Blaster Coil Rev limiter and Shift Light BBK Long Tubes and off-road pipe. Flowmaster Super 40's and stainless/electric exhaust cut-outs. TKO600 5 speed with Steeda Tri-Ax shifter and DFX clutch with Fidanza aluminum flywheel. Aluminum driveshaft and loop. Welded subframe connectors and 6 point cage with swing-out arms. Champion aluminum radiator/Black magic electric fan and Elderbrock HD aluminum water pump. Lakewood drag struts/shocks and upper/lower control arms. Motorsport HD 31 spline differential with 3:73's and 31 spline axles. 130 amp alternator and hatch mounted battery. Brakes redone to stock specs minus cross drilled rotors.
Gallery
Comments
There are no comments to display.
