General Information
Year
2000
Make
Mustang
Model
Roush
List of Mods Todate:
Roush Build #2568
Roush Stiffer Front and Rear Springs & lowered
Roush Side Exhaust (w/New Style Tips)
Roush Bilstein Tuned Shocks
Roush Pinion Snubbers
18X9 Roush Chrome Rims
Complete Roush Stage II Body Kit
Roush Larger Front and Rear Sway Bars with Roush Bushings
Roush Lower Control Arms
Roush Subframe Connectors (welded)
Roush Fuel Gauge
Roush Boost Gauge
Innovate Wideband Gauge
Roush Indo Glow Gauge Cluster
Roush badges, interior enhancements & trunk mounted tool kit
Kenne Bell Supercharger @ 12psi
LFP Double Bypass Cobra Intercooler
Kenne Bell Big Air Cold Air Intake w/16" Filter
Kenne Bell Boost-a-Pump wired up full time
Lighting 90mm Mass Air
75mm Accufab Throttle Body
42lb Fuel Injectors
Custom Blower Cams
Long Tube Headers
O/R H-Pipe
Spintech Mufflers
3:73 Gears
Pro Motion “Yellow” Hi Rev Clutch
OEM 03 Cobra Hood with Redline Hood Struts
Maximum Motorsports Caster/Camber Plates
Maximum Motorsports Front Strut Tower Brace
Kenny Brown Rear Shock Tower Brace
Rear Seat Delete
Corbeau A4 Racing Seats both driver and passenger
5 Point Seat Restraints
4 Point Roll Cage (Welded) with removable camera mount
Mach1 Grill Delete
Sequential Tail Lights
Griggs Adjustable Tri-Link System
Yellow Top Optima Battery and Steeda Trunk Battery Box Relocation
Brembo 4 Piston Front Calipers
Brembo Steel Braided Brake Lines
Brembo 15" Front Slotted Rotors
Hawk HPS Brake Pads
Baer EradiSpeed 14.5" Rear Slotted & Cross-drilled Rotors
Pro 5.0 Short Shifter (W/Tri-Ax Handle)
FR 500 Steering Wheel (FR500 Wheel is the SH*T)
Front Nitto's 555/Rear BFG DR's
Custom tuned with Diablo Predator Tuner
A few internal/external modifications
Roush Build #2568
Roush Fuel Gauge
Roush Boost Gauge
42lb Fuel Injectors
Custom Blower Cams
Long Tube Headers
O/R H-Pipe
Spintech Mufflers
3:73 Gears
Rear Seat Delete
Mach1 Grill Delete
Hawk HPS Brake Pads
