Showcase cover image for RStrick0352's 2007 Ford Mustang GT
General Information
Year
2007
Make
Ford
Model
Mustang GT
Grabber Orange 6 spd
Intake: JLT CAI and twin 62mm throttle body
Exhaust: American Racing Headers longtubes (1 5/8 primaries), MAC
offroad Prochamber, Moroso Spiral flow mufflers dumped
Engine: Steeda Under drive pullies, Meizre Electric water pump, Autolite
HT-0 spark plugs, Steeda IMRC delete, 180' thermostat, canton steel high capacity oil pan w/ windage tray, Comp cams stage 2 SPR cams (part # 127500), cam phaser mods, high load valve springs, steel retainers, Coming soon: Sniper COP's, ported heads, Manley stainless valves, FRPP BOSS Big Bore w/ Cobra crank, Eagle 200 forged H-Beam rods, Diamond custom pistons, all ARP 2000 hardware, Cometic gaskets, federal mogul bearings, total seal rings, head studs.
Drivetrain: Dynotech custom length aluminum driveshaft, Currie Enterprises 9 inch swap w/ 4.30 gears and nodular sportsman 3rd member w/ pinion supports, Steeda Tri Ax shifter, CHE K-member brace w/ torque limiters, BMR drive shaft loop and tunnel brace. Coming soon: FB performance Automatic w/ full manual valve body and trans brake
Suspension: Front: BMR tubular lower contol arms, BMR tubular radiator support/ swaybar delete, SLP line lock/ roll control, cross drilled and slotted rotors, QA1 adustable coil over, BMR tubular K- Member
Rear: GT500 springs, BMR rod end adjustable lower control arms, BMR solid adjustable upper control arm w/HD mount, BMR adjustable panhard rod w/ HD brace and relocation bracket, QA 1 adjustable shocks, 94 GT rear brakes, cross drilled and slotted rotors, BMR extreme anti roll bar, BMR rear tunnel brace and DS loop
Power Adder: Ny Trex Triple Threat nitrous system with and HSW Plate conversion.
Interior: Corbeau racing seats, Modular mustang racing rear seat delete,
custom switch mounts for nitrous, auto meter digital tach/ shift light, MSD Dash hawk system monitor, SOS center dash guage cluster with Auto Meter Phantom series wideband and nitrous pressure guage and boost guage. Custom fabbed 6 point roll cage w/ swingout side bars. Coming soon: Taylor battery relocation kit.
Exterior: Steeda race cowl induction hood, Steeda shorty antenna
Wheels and tires: FR-500 black chrome 18x9 front M/T Sportsman S/R's 28x9, 18x10 rear M/T Sportsman S/R's 28x10
Track shoes: Billet specialties 15x10 rear w/ MT ET street drag radial 28x12.50x15 (325x50x15)
15x4 fronts w/ 26inch tall tire
Gallery
Comments
There are no comments to display.
