General Information
Year
1996
Make
Ford
Model
Mustang SVT Cobra
1996 Ford Mustang SVT Cobra
Street:
Mickey Thompson 275/40/17 Drag Radials
Cobra R 17"x9" Chrome Wheels
Strip:
Weld Racing 15x8" Rear Aluminum Drag Wheels
Weld Racing 15x3.5" Front Aluminum Drag Wheels
Mickey Thompson E/T Street Drag Slicks
Steeda Camber/Caster Plates
Strange Engineering Adjustable Rear Shocks
Strange Engineering Adjustable Front Struts
Steeda Drag Springs
Airlift Air Bag
Battery Relocation Kit
Steeda Full Length Subframe Connectors
UPR Tubular Front K-Member
UPR Coil Overs
BBK Long Tube Headers
Off-Road H-Pipe
SpinTech Catback Exhuast
Accufab Single Blade Throttle Body
C&L TrueFlow Inlet Pipe
90mm C&L MAF Sensor
K&N FIPKII Air Intake Kit
MSD Coil Packs
MSD Spark Plug Wires
Motorcraft Copper Spark Plugs
Walbro 255# Fuel Pump
TKO-500 Transmission
Spec Stage III+ Clutch
Spec Flywheel
Lakewood Bellhousing & Scatter Shield
MGW Shifter
8.8" Rear End
Ford Racing 5-Speed Shift Knob
4.10 Ford Racing Performance Parts Ring & Pinion
Ford Racing Performance Products Rear End Girdle w/ FRPP Studs
Aftermarket Rear Swaybar (Broke 2 Factory Swaybars... weak.)
Autometer Electrical Fuel Pressure Gauge
Autometer Mechanical Boost Gauge used for Vacuum
Autometer Instrument Cluster Bezel
Optima Yellow Top Battery in Trunk
Cosmetic:
UPRProducts Crystal Clear Cobra Headlights
BlueOvalIndustries Crystal Clear Fog Lamps
Cobra Front Grill Emblem
Cobra Black Rear Bumper Inserts (+500 Horsepower)
Street:
Strip:
Steeda Drag Springs
Airlift Air Bag
UPR Coil Overs
Off-Road H-Pipe
90mm C&L MAF Sensor
MSD Coil Packs
Spec Flywheel
MGW Shifter
8.8" Rear End
Cosmetic:
