Showcase cover image for Scott2's 2008 Mustang GT/CS
General Information
Year
2008
Make
Mustang
Model
GT/CS
Limited-edition 2008 Ford Mustang GT California Special assembled at Auto Alliance International on 05/05/2008. This vehicle is #4,688 of a build of 4,918 coupes and is 1,215 of 1,278 manufactured in Dark Candy Apple Red. Purchased 100% stock in April 2009.
Engine:
• Ford Racing Performance Parts (FRPP) 4.6 Liter Aluminator Short Block 9.8:1 Compression Ratio
• FRPP High Flow CNC Ported 3V Cylinder Heads , M-6050-463VP3 (LH) and M-6049-463VP3 (RH)
• FRPP 4.6L 3-Valve Cam Phaser Limiter Kit
• FRPP 4.6L 3C Camshaft Drive Kit
• FRPP Performance Head Gaskets
• FRPP 3V Spark Plugs 12 MM (M-12405-3V12MM)
• ARP 4.6L 3-Valve Head Studs
• Vortech V-3 Si-Trim HO Polished Supercharger with Charge Cooler
• Vortech 6 Rib Supercharger Pulley (3.25”)
• ATI Harmonic Balancer – ATI Super Damper Serpentine Series
• ARP Harmonic Damper Bolt M12 x 1.50 x 2.085”
• AFCO High Performance Aluminium Radiator
• FRPP SVT Performance Cooling Fan
• AFCO Dual Pass Heat Exchanger with Dual Spal Fans
• Canton Racing Products Aluminum Coolant Expansion Tank
• Comp Cams Stage 2 Blower XFI™ SPR Ford 4.6L/5.4L Modular 3V Cams, 127550
• DiabloSport MAFia
• FRPP High Performance Oil Filter FL-820
• Hypertech Power Stat 160 Degree Thermostat Mustang GT (05-09)
• Metco Motorsports Four Piece Idler Pulley Set
• Meziere Enterprises 55gpm Electric Water Pump
• Meziere Enterprises Electric Water Pump Relay Kit
• Meziere 20GPM Electric Intercooler Pump
• Mishimoto Silicone Radiator Hose Kit
• Moroso Performance Parts Aluminum Intercooler Coolant Tank
• Moroso Performance Parts Ford Modular 7qt Capacity, 6 ½” Deep Sump Oil Pan
• Canton 4.6L / 5.4L Oil Pan Stud Kit
• PMAS HPX MAF Sensor
• PRW SFI 3V 8-Bolt Flexplate - PRW Platinum Series SFI-Rated Steel Flexplate
• ARP Flexplate Bolts (8), M10 x 1.00 (UHL .800)
• Purple 5W20 Synthetic Oil
• Russell Performance -12AN Stainless Steel Hose and Aluminum Fittings for Intercooler Coolant Lines
• Shelby Performance Parts Oil Pressure Gauge Adapter
• Triangle Speed Shop 3V/GT500 Oil Pump Assembly w/ Billet Gears & 2013 SVT Billet Backing Plate
• TurboXS Racing Blow Off Valve
• UPR Billet 3 Bolt Belt Tensioner and 76mm Carman Goudey Pulley
Fuel Delivery:
• FRPP 62mm GT Billet Throttle Body
• FRPP 4.6 Liter 3V Performance Intake Manifold
• FRPP GT 500 Dual Fuel Pump System
• Injector Dynamics ID 1000 Fuel Injectors
• Fore Precision Billet Fuel Rails
• Fore Precision Mustang GT Fuel Rail Install Kit
• Russell Performance Stainless Steel Fuel Hose Kit
• Gasoline - Petro Canada - 94 Octane
Exhaust:
• American Racing Headers Stainless Steel Long Tube Headers 1 ¾” Primaries
• American Racing Headers X-Pipe Crossover with Cats
• Magnaflow Cat-Back 3” Stainless Steel Exhaust System with Magnapacks
• FRPP 3V Header Gaskets
• Stack Racing Stainless Steel Exhaust Hangers
Under Hood Styling:
• California Pony Car Radiator Extension Covers
• Cervini’s Auto Design Hood Struts
• Kirban Performance Chrome Plated Hood Latch
• Moroso Fabricated Aluminum Valve Covers
• Moroso Aluminum Brake Reservoir Cover
• Moroso Aluminum Fuse Box Cover
• Polished Stainless Steel Fender Bolts
• Steeda Polished Billet A/C Check Valve Cover
• Stack Racing Chrome Cap Dress Up Kit
• UPR Polished Vapour Vent Cap Cover
• UPR Polished Billet Cowl Pin Cap Covers
• UPR Polished Billet Throttle Body Actuator Cover
• UPR Polished Billet Coil On Plug (COP) Covers
• UPR Polished Billet Oil Dipstick Handle
Tuning Software:
• SCT X3 Tuner - Tuned by DaSilva Racing
Electronics:
• AeroForce Interceptor Scan Gauge (Monitors Intake Air Temperature & Fuel Pump Duty Cycle)
• Auto Meter Nexus Series Gauges: Fuel Pressure, Wideband Air/Fuel Ratio, Vacuum/Boost, Oil Pressure, Coolant Temperature and Transmission Temperature
• Auto Meter Nexus 8 Channel Sensor and Remote
• Pioneer Electronics In-Dash Navigation Receiver with 7” WVGA Capacitive Touchscreen Display AVIC-8000NEX
• Pioneer Electronics Front Speakers TS-D6802R
• Roush Performance Vent Gauge Pod
• Speed of Sound Dove Gray “A” Pillar Triple Gauge Pod
• Speed of Sound Center Dash Triple Gauge Pod
• Taylor Performance Parts Trunk Mounted Aluminum Battery Box
• Optima Yellow Top D34 Battery
Driveline:
• Axle Exchange 4” One-piece Aluminum Drive Shaft w/Pinion Flange
• BMR Suspensions Front Drive Shaft Loop
• Canton Racing Products Automatic Transmission Fluid Expansion Tank
• Circle D Specialties 5R55 Multi Disk 245mm 3000 Stall Performance Torque Converter
• Performance Automatic 5R55 Deep Aluminum Pan, Stainless Steel Fasteners and Filler Tube Set with Dipstick
• Performance Automatic Hardened Transmission Input Shaft for Ford 5R55S
• TCI Auto StreetFighter Ratchet Automatic Shifter
• TCI Auto Hi Performance Transmission Servo Kit, 3rd Gear Servo Kit
• TCI Auto Hi Performance Transmission Servo Kits, 4th Gear Servo Kit
• Ford Racing Performance Parts 4.10 : 1 Ring & Pinion
• Ford Racing Performance Parts Ring and Pinion Installation Kit (B)
• Ford Racing Performance Parts 8.8” Aluminum Differential Girdle/Cover with Stainless Steel Fasteners
• Ford Racing Performance Parts Friction Modifier
• Ford Rear Axle Vent Hose Assembly
• TA Performance 8.8” Bearing Cap Stud Kit
• Lube Locker 8.8” Differential Gasket
• Royal Purple Max-Gear SAE 75W140 Gear Oil
Air Ride by Air Lift Performance:
• AutoPilot V2 Digital Controller
• Twin VIAIR 380C Chrome Compressors
• Polished Aluminum 2.5 Gallon Trunk Tire Well Mounted Air Tank
• Triple SMC Water Traps
Front Suspension / Bracing:
• Air Lift Performance 30-way Damping Adjustable Struts with Camber Plates
• Air Lift Performance Front Sway Bar End Links
• BMR Suspensions Tubular K-Member
• BMR Suspensions Tubular A-Arms
• BMR Suspensions A-Arms Support Brace
• BMR Suspensions Radiator Support with Sway Bar Mount
• BMR Suspensions Chassis Brace Radiator Support
• Ford Boss 302 Strut Tower Brace
• Maximum Motorsport Strut Mount Hardware Kit, Strut to Spindle
• Steeda Adjustable Front Sway Bar
Rear Suspension / Bracing:
• Air Lift Performance Tapered Sleeve Air Springs
• Air Lift Performance 30-way Damping Adjustable Shocks
• BMR Suspensions Xtreme Anti Roll Bar
• Bump Stop Frame Brackets Removed
• Ford Racing Performance Parts Mustang GT Jounce Bumpers
• Jounce Bumper Relocation Plates
• Steeda Adjustable Panhard Bar
• Steeda Heavy Duty Panhard Bar Brace
• Steeda Adjustable Upper Control Arm
• Steeda Billet Lower Control Arms
• Sway Bar Axle Housing Mounts Trimmed for 15”x10” Rim Clearance
• UPR Lower Control Arms Relocation Brackets
Interior:
• Amustangrocksleather.com ¾ Length Leather E-Brake Arm Cover
• Amustangrocksleather.com Padded Leather Arm Rest Cover
• Black Accent Trim Welt on Doors
• Diode Dynamics Custom GT/CS Aluminium Door Handle Plates
• Ford Racing Performance Parts - Ford Racing Logo Floor Mats
• Ford Racing Performance Parts GT500 Leather Wrapped Steering Wheel
• Glove Box Trunk Release Push Button
• MMS “Bright” White LED Map Lights
• Steeda Billet Pedal Covers
• UPR Polished Billet Front Speaker Rings
• UPR Polished Billet Mirror Control Knob & Bezel
• UPR Polished Billet Door Pins
• UPR Polished Billet E-Brake Handle
• UPR Polished Billet Power Plug
• UPR Polished Billet Cup Holder
• UPR Polished Billet Ultra Light Door Handles
• UPR Polished Billet Designer Door Pin Bezels
• UPR Polished Xtreme Billet Window Switch Plates
• UPR Polished Billet Map Light Buttons
• UPR Polished Billet Seat Recliner Lever
• UPR Polished Billet Power Lumbar Seat Switch Button
• UPR Polished Billet Power Seat Button Covers
• UPR Polished Billet Headlight Knob Cover
• UPR Polished Billet AC Knob Covers
• UPR Polished Billet Large Oval Clothes Hangers
• UPR Polished Billet Lock Switch Covers
Exterior:
• Agent 47 Brake Cooling Scoops
• American Muscle Mirror Covers, Paint Code: JV
• Anzo USA Euro w/Amber Reflector Park Lights
• Cervinis Ram Air Type IV Hood with Billet Inserts
• Covercraft Technalon Car Cover – For Car Storage
• Ford Racing Performance Parts SVT GT500 Spoiler
• Raxiom Smoked Halo Fog Lights
• Raxiom 2010 Style Smoked Halo Headlight
• Raxiom Gen 5 Sequential Tail Lights ( 2013 Style )
• Silver Horse Racing California Special Honeycomb Lower Grille
• Silver Horse Racing Honeycomb Deck Lid Panel
• Stack Racing 8” Shorty Antenna
• Stack Racing Black Tail Light Trim Bezels
• Street Scene Center Fog Light Honeycomb Grille
• UPR Polished Billet Aluminum Gas Cap Cover
Brakes, Tires and Wheels
Front:
• Nitto NT-555 - 255/45 R18 103W (Street)
• SVT GT 500 Mustang - 5-Lug, 4.5” Bolt Circle, 7.125” Backspacing, 45mm Offset 18” X 9.5” (Street)
• Ford Racing Performance Parts Open End Wheel Nuts for SVT Wheels (Street)
• M&H Racemaster Front Runner Radial 185/55/17’s (Off Road )
• Race Star Industries Drag Wheel 5-Lug, 2.5” backspacing, 17” x 4.5” (Off Road )
• McGard Drag Racing Lug Nuts (For Race Star Wheels with ARP Studs) (Off Road)
• Agent 47 Brake Cooling Kit
• Baer Pro+ 6P, Six Piston Calipers, 2 Piece 14” Slotted and Drilled Rotors & Stainless Steel Lines
• Ford Racing Performance Parts Front Hubs with ARP Long Wheel Studs
• Russell Performance Speed Bleeders
Rear:
• Nitto NT-555 - 285/40 R18 101W (Street)
• SVT GT 500 Mustang - 5-lug, 4.5” Bolt Circle, 7.125” Backspacing, 45mm Offset 18” X 9.5” (Street)
• Mickey Thompson ET Street Radial 325/50/15’s (Off Road)
• Race Star Industries Drag Wheel, 5-Lug, 7.5” Backspacing, 15” x 10.0” (Off Road)
• ARP Long Wheel Studs
• Baer Decela Slotted and Drilled Rotors
• Dupli-Color Red Painted Calipers
• Stop Tech Stainless Steel Brake Lines
Winter 2013 / Spring 2014 Build:
• Air Lift Performance Digital Combo Suspension Kit - Completed
• AFCO High Performance Aluminium Radiator - Completed
• AFCO Dual Pass Heat Exchanger with Dual Spal Fans - Completed
• B&M Racing and Performance Products Hi-Tek Transmission Cooling System
• BMR Suspensions Upper Control Arm Mount
• BMR Suspensions Polyurethane Differential Bushing Kit
• BMR Suspensions Boxed Subframe Connectors
• BMR Suspensions Radiator Support with Sway Bar Mount - Completed
• BMR Suspensions Chassis Brace Radiator Support - Completed
• Fore Triple Hat (Dual Pump) Return Style Fuel System
• Ford Racing SVT Performance Cooling Fan - Completed
• Flaming River Battery Disconnect Switch
• Injector Dynamics ID 1000 Fuel Injectors - Completed
• LED Map Lights and Black Accent Trim Welt on Doors - Completed
• Meziere 20GPM Electric Intercooler Pump - Completed
• Mishimoto Silicone Radiator Hose Kit - Completed
• Painless Performance Products Auxiliary Fuse Block with 7 Circuits
• PMAS HPX MAF Sensor - Completed
• Raxiom 2013 Style Sequential Tail Lights – Completed
• Raxiom Smoked Halo Fog Lights – Completed
• Raxiom 2010 Style Smoked Halo Headlights - Completed
• Relocate IAT Sensor to an FRPP Intake Runner
• SLP Line Lock Kit
• TurboXS Racing Blow Off Valve - Completed
Gallery
Comments
There are no comments to display.
