General Information
Year
1997
Make
Ford
Model
Mustang GT
1997 Mustang GT in Deep violet. 1 of 7000
2001 5.4L V8 swapped
4.5" Housing / Slot Style Maf
80lbs Injectors
Magnafuel ProTuner 625
FRPP shortie Headers
MSD coilpacks
FRPP 9mm wires
170* Thermo stat
BR7 Spark Plugs
Borg Warner S475
Custom Fabricated Turbo Kit
Stock Heat exchanger
CXR intercooler pump
Trunk Mount battery
Moroso kill switch + homemade bracket
Tuned by Kevin MacDonald @ JPC
Built transmission with upgraded clutches and welded stub shaft
PA Full Manual valve body with trans brake
UPR Tubular K Member
UPR Tubular A Arms
UPR Coilover Kit
UPR Caster Camber Plates
UPR Spherical Lower control Arms
UPR Upper Control ARms
UPR Upper Housing Bushings
Maximum Motorsports Subframe Connectors
Racecraft Manual brake conversion
Flaming River Manual Rack
Maximum Motorsports steering shaft
Strange 35 Spline Axles
Strange 35 Spline Spool
Hardend Studs
Strange C Clip Elimintors and billet caliper mounts
Ford Racing 3.55 Gears
....i think thats it.
Its got like a headunit, lights, racing seats and louvers too.
80lbs Injectors
MSD coilpacks
FRPP 9mm wires
170* Thermo stat
BR7 Spark Plugs
Borg Warner S475
Trunk Mount battery
UPR Tubular A Arms
UPR Coilover Kit
Hardend Studs
