Showcase cover image for skidad62's 2003 Ford Mustang Centennial Edition
General Information
Year
2003
Make
Ford
Model
Current Modifications:
Engine
4.6 litre 2V MMR 4.6 Street Mod 1000 (up to 1000 RWHP) - "The Aluminator Shortblock Killer"
*Brand New Cast Iron 2004 Cobra Block, torque plate bored and honed
*New 4340 Forged 3.543 stroke Cobra Crankshaft w/micro polished journals
*New 4340 5.933 Manley H-beam Rods w/ARP rod bolts (shotpeened, magnafluxed and weight matched)
*New Forged Manley dished pistons (9.22 compression with notches cut for the 274 cams)
*Speed Pro file fit rings (precision file fit to my blower)
*Speed Pro/Federal Mogul or Clevite Tri-metal Rod and ACL Performance Main bearings
*MMR block side bolts
*ARP Mainstuds
*MMR Street/Racing Oil Pump
*MMR/Felpro Extreme Duty Headgaskets
*ARP Headstuds
*MMR windage tray and hardware kit
*FRPP 2v stage 1 ported heads
*Comp Cam Xtreme Energy™, XE274H cams
* Comp Cam Beehive valve springs
* Moroso Valve cover Breather kit for Supercharged applications
* MMR Street/Strip 7 Qrt. Oil pan
Vortech V2 SQ Supercharger - 15 lbs of boost
2.80 Reichard Racing 8 rib supercharger pulley
BBM 8 rib conversion kit
Thump Racing tensioner
ProCharger air to air intercooler
3" custom intercooler piping
Vortech Mondo Blow off valve
Anderson Powerpipe
K&N 4" x 10" air filter
VMP 05+ slot style 95 mm MAF
04 Cobra fuel tank
Twin Ford GT Supercar pumps
Zone 5 MDM pump module
Fore Precision billet fuel hat
-8 an braided s/s fuel lines
Fore Precision billet fuel rails
Aeromotive fuel filter
60 lb Ford Racing Fuel Injectors
Accufab 75mm Ported Throttle body & plenum
Moroso aluminum radiator overflow tank
Magnaflow 2.5" s/s piping & tips
2010 GT 500 mufflers
MAC prochamber for LTs
Speed of Sound dual gauge pod pillar
Autometer electric fuel pressure gauge
AEM Uego digital wideband gauge
Driveline
Centerforce Dual Friction Clutch kit
Fidanza Aluminum Flywheel
FRP bearings
FRP 410 gears
FRP Aluminum Driveshaft
FRP Driveshaft Safety Loop
Moser 31 spline axles & c clip eliminators
Eaton 31 spline True Trac differential
Motive 410 gears & install kit
Trick Flow differential cover
Differential stud kit
SLP line lock
Cobra front brakes
ARP long studs for all 4 corners
FRP Cobra front brake rotors
Hawk HPS pads (front & rear)
MGW short throw shifter
18 x 9/10 Black Saleen wheels
Toyo T1R 255/40/18 fronts
Toyo 888R 305/35/18 drag radial rears
15 x 3.5/8 Prostars and MT Sportsman fronts and 26 x 10.0 MT ET Drag rears
Suspension & chassis
RPM 5 point rollbar
Simpson 5 point seat belt harness
Corbeau TRS seats
Steeda 4 Bolt Caster Camber Plates
Steeda Lowering Sport Springs
Steeda 3 point strut tower brace
Appearance
2004 Cobra OEM Hood
2004 Cobra front bumper & chin spoiler
UPR stainless steel radiator cover
Billet hood extractor grills
Cobra Grille delete
14 inch Antenna-X
6,000k HID High & low beams
6,000k HID fogs
2001 FRP Bullit Aluminum Fuel Door
Window tint 20% rear & 35% sides
2004 Cobra Cluster and Boost gauge
FRP chrome oil cap
MMR rear seat delete
Pending mods on order
Vortech V7 YSI trim supercharger
Edelbrock Victor Jr EFI intake
6061 intake elbow
Treadstone intercooler
MMR A/C delete
Steeda battery relocation kit
Gallery
Comments
There are no comments to display.
