Showcase cover image for smccoy916's 2001 Ford Mustang GT
General Information
Year
2001
Make
Ford
Model
Mustang GT
Forged cobra crank
probe 18.1cc pistons .020 over
Manley H-beam Rods
MMR high flow oil pump
CLOYES hex-a-just timing set
All ARP hardware
Patriot Stage II heads Reworked by Rex Hutchinson Racing Engines (Patriot Heads suck!)
Trick Flow (Felpro) MLS head gaskets
COMP CAMS 262AH
75mm TB & Elbow
Steeda Timing adjuster
FlowMaster Cat Back
BBK X-pipe
Sniper Delta Force tuning software & SCT pro racer package
PLX R-500 Wideband O2 system W/EGT probes
Centerforce DF (replaced the spec stage 2+ after replacing two clutch cables)
Fidanza 12lb flywheel
Lakewood Drag shocks
Welded subframe connectors
13in Cross/slotted rotors and bullit calipers
GMS Double adjustable rear links
Steeda Tri-ax shifter
Ford Racing 373 Gears
Cobra 31 spline Diff
Alloy 31 spline axles
Vortech S-trim
Custom 4" front mount intercooler
Power Pipe
HPX slot MAS
Gallery
Comments
There are no comments to display.
