Showcase cover image for Spurred Snake's 2003 Mustang GT
General Information
Year
2003
Make
Mustang
Model
GT
Mod list includes:
Maximum Motorsports Max Grip Box Kit
MM K-member (with 2-point brace)
MM Front Control Arms
MM Torque-arm
MM Panhard Bar
MM XL Series Full-length Subframe Connectors
MM Coil-over Conversion Kits, Front and Rear
Hypercoil Coil-over springs
MM Caster/Camber Plates
MM Road Race Rear Lower Control Arms
Bilstein HD series struts
Bilstein HD series shocks
MM Adjustable Rear Swaybar
MM Aluminum Steering rack Bushings
MM Solid Steering Shaft
MM Bumpsteer Kit (adjustable outer tie-rod ends)
MM Strut Tower Brace
MM Front Swaybar Relocation Kit
Front Swaybar Bushings
Front Swaybar End Links
Brakes:
Wilwood Super Lite SL6 front calipers and Dyna Lite DL4 rear calipers Big Brake Kit
GT slotted rotors - Rotors are 2 piece with aluminum hat.
Interior:
MGW Short Shifter
Sparco Steering Wheel
Corbeau Race Seats
Rear end:
Trickflow Aluminum Diff cover
Ford Racing Performance Products 4:10 gears in differential
Eaton Posi-traction
Moser 31 spline axles
Engine:
Trickflow 75mm Throttle Body and Plenum
K & N High Flow Air Filter
Summit UDP
Exhaust:
MAC ceramic coated Long Tube Headers
MAC Prochamber mid pipe
Flowmaster 40's
Gallery
Comments
There are no comments to display.
