Showcase cover image for stal94gt's 2003 Ford Mustang Cobra
General Information
Year
2003
Make
Ford
Model
Mustang Cobra
2003 FORD MUSTANG COBRA
STOCK MOTOR
WHIPPLE 2.9L (175AX)
LFP SBTB
SCT BA 3000 MAF
BILLET FLOW IDLERS
EVEN FLOW HEAD COOLING MOD
SPEC 3+ CLUTCH KIT
SPEC BILLET STEEL FLYWHEEL
STOCK TRANS WITH 26 SPLINE INPUT SHAFT
SRA SWAP
UPR CHROMOLY LOWER CONTROL ARMS
GRANATELLI DOUBLE AJUSTABLE UPPER CONTROL ARMS
URETHANE AXLE BUSHINGS
DETROIT TRUE TRACK DIFF
31 SPLINE AXLES
3.73 RING/PINION
MOROSO SPIRAL FLOW CAT BACK
UPR O/R X PIPE
40 AMP BAP
DUAL FORD GT PUMPS
MODIFIED FPDM
60# INJECTERS
STEEDA TRI AX SHIFTER
N2MB WOT BOX
SCT X3 TUNER (TUNED BY XXX)
STOCK FOR LIFE!
OLD CAR 2000 MUSTANG GT
ENGINE: MMR 900 SB
MANLEY FORGED -18CC PISTONS
4340 FORGED H BEAM RODS
TOOL STEEL WRIST PINS
CLEVITE ROD AND MAIN BEARINGS
TOTAL SEAL PISTON RINGS
04 COBRA BLOCK
MMR STAGE 1 PORTED HEADS
COMP CAMS HIGH LOAD SPRINGS
TITANIUM RETAINERS
STOCK VALVES
TIMESERTS
TRICK FLOW TRACK HEAT INTAKE MANIFOLD
75 MM THROTTLE BODY
DUEL COBRA FUEL PUMPS
40 AMP BAP
LETHAL PERFORMANCE -8 AN FUEL LINES
COBRA GAS TANK
LIGHTNING MAF WITH MAFIA EXTENDER
MOTO BLUE COIL PACKS
MEZIERE ELECTRIC WATER PUMP
180 DEGREE THURMO
63 LBS INJECTORS
VORTECH V3 SI SUPERCHARGER WITH 3.00 rr PULLEY
AIS ALCOHOL INJECTION SYSTEM
ANDERSON FORD MOTOR SPORTS POWER PIPE
CX 4 CORE AIR TO AIR INTERCOOLER
TIAL 50MM BLOW OFF VALVE
EXHAUST:
FRPP HEADERS
PYPES O/R X PIPE
MOROSO SPIRAL FLOW MUFFLERS
PYPES FLOW TUBES
2.5 TAIL PIPES WITH 3.5 STAINLESS TIPS
Suspension/Chassis:
ENERGY EXTREAM MOTOR MOUNTS
LAKEWOOD TACTION BARS
UMI TORQUE BOXES
FULL BODY SUB FRAMES
Drivetrain:
FRPP 3.73 RING/PINION
STEEDA TRIAX SHIFTER
UPR CLUTCH QUADRANT FIRE WALL AJUSTER
AJUSTABLE CLUTCH CABLE THAT WAS MADE IN THE LAND OF CHINA
ZOOM STAGE 3 CLUTCH KIT
FRPP CLUTCH FORK
MAXIMUM MOTOR SPORTS CLUTCH PEDAL AJUSTER
FMS DRIVE SHAFT
PMP T45
Electronics:
SCT X3 TUNER
LED LIGHTS TO TELL ME MY WATER PUMP AND ALCOHOL ARE ON!
DYNO TUNE BY XXX MOTORSPORTS
Gallery
Comments
There are no comments to display.
