General Information
Year
2004
Make
Ford
Model
Mustang GT
Engine/Drivetrain:
MPH 800hp Shortblock w/ 9.43:1 CR
MPH custom blower cams
Stock PI heads with Manley Nextec springs
78mm BBK TB/Plenum
JBA shortys
Bassani Catted X
Borla Stingers
K&N drop in filter w/stock intake tube
Mezier Electric water pump
Trick Flow UDPs
Sniper Tuned on 91 octane
MSD Launch Box 2-step limiter
Dynojet Wideband Commander
271rwhp & 286rwhp Mustang Dyno
4r70w Auto Trans
PA SFI Flexplate w/ARP bolts
DirtyDog 9.5" 4,000rpm stall converter
Trans-Go HD-2 Shift kit
Hayden 30,000 GVW Trans Cooler
FRPP Alum DS
FRPP 4.10 gears
FRPP 31-spline Cobra Diff w/CF clutches
Alloy USA 31-spline forged axles
Rear End Girdle
Tires/Suspension:
MM FLSFCs
UPR Front Coilovers
UPR 4 bolt CC-Plates
14-175 rate front springs
Stock rear springs with 1 coil cut
Team Z relocated UCAs
Team Z double Adj. LCAs
Strange Adjustable Shocks/Struts
Welded TQ. Boxes
Summit Drive Shaft Safety Loop
removed sway bar, quad shocks, dogbone, spare/jack
27x11.5 Hoosier QTPs on 15x9 Draglites
fronts are 215/65-15 on 15x7 Draglites
(times in sig is on MT drag radials and with stock tr3650)
Coming soon:
Built trans from BC Auto, deep sump trans pan, custom zinc plated trans cooler lines,
78mm BBK TB/Plenum
JBA shortys
Bassani Catted X
Borla Stingers
Trick Flow UDPs
4r70w Auto Trans
FRPP Alum DS
FRPP 4.10 gears
Rear End Girdle
Tires/Suspension:
MM FLSFCs
UPR Front Coilovers
Welded TQ. Boxes
Coming soon:
