Showcase cover image for tg1227's 2004 Ford mustang
General Information
Year
2004
Make
Ford
Model
mustang
Color
ow
Packages
gt
History
bought the car mostly stock with borla exhaust, 18 wheels and coldair intake. car is completely different now and still growing, currently under construction
2004 Ford mustang (ow)
Modifications
Drivetrain
Engine :
-Current production aluminum block
- MMR 1000 4.75L stroker rotating assembly .020 over 9.5.1 comp.with 38cc heads
-ARP hardware throughout
-MMR windage tray/oil pan gasket
-MMR billet oil pump gears
-MMR billet aluminum timing chain pivot arms
- Cobra engineering upgraded pivot arm studs
-upgraded metal timing chain tensioners
-Innovators west 15% overdrive balancer
-Meizer electric waterpump and wiring kit
-Trick flow track heat twisted wedge 185 series cylinder heads 38cc with high lift springs
- Cushman motorsports 2.5 blower cams
-GT40 supercar roller rockers
-ARP head studs
-Edelbrock intake
-6061 elbow
-Accufab 75mm throttle body
-MMR iac relocation kit
-Poly motor mounts
-Canton reservoir tank
Power adder:
-Vortech V3 si
-3.12 pulley
-4" power pipe
-Hpx slotstyle maf
-Cx Racing 4" intercooler
-Tial Q 50mm blowoff valve
-K&N filter
Exterior
wheels, hood,bumper
Audio
Tko 600, 31 spline Moser axles with ford racing track loc differential, 3.73
Suspension
eibach sport line springs
Wheel and Tire
18" deepdish, mt et streets on the rear.
Gallery
Comments
There are no comments to display.
