Showcase cover image for thecryptkeeper's 1984 Stang GT 350
General Information
Year
1984
Make
Stang GT
Model
350
First off, its a true 25th anniversary of the old GT 350. I even have matched the numbers up for it. It has a built 5.0L 302cu High Output engine with a brand new 600 CFM Holley Carb (4160 series, 4bbl, electronic choke), Weiand Action +Plus Manifold (idle-6000rpm, 1.90 port size, low rise dual plane),new pistons and rods. It has GT-40 heads in it has been bored over .030, but do know that they are performance heads. Also has a hydrolic roller cam, and the T-5 transmission shifts excellent to 3.27 gears and has a b&m shifter. The exhaust system includes custom made midlength headers that flow into duel pipes that cut off right before the axle.
The main vin decodes as follows:
1FABP USA, ford car, active seatbelts
28 3-door hatchback GT series
M V8, 5.0 liter 302-4V HO engine
E 1984 model year
F dearborn assembly plant
178464 consecutive build number
The door vin decodes as follows:
05/84 may 1984 schelduled build
9L oxford white exterior
B4 midwestern (ford of canada)
61B hatchback
PA red cloth interior
GD tape/decals for 20th anniversary gt350
8 am/fm radio and cassette
C sunroof
E 3.27 rear end gears
T automatic overdrive transmission
Gallery
Comments
There are no comments to display.
