General Information
Year
2001
Make
Ford
Model
Mustang Cobra
Under Drive Pulleys
Brenspeed 91 Tune
HD clutch
Built D&D Performance T-56 6-speed w/ Pro 5.0 shifter
Aluminum Driveshaft
SRA Swap w/ Eaton Posi 8.8inch rear end and FRPP 4.10's
31 spline Moser axles
Maximum Motersports(MM) Full Length Subframe Connectors
MM Extreme Duty Rear LCA's
MM Panhard Bar
MM Torque Arm
MM Caster/Camber plates
Eibach pro-kit springs up front, H&R T/A springs in rear
Bilstein Shocks/Struts
Custom catted mid-pipe
Magnaflow Magnapack mufflers w/ Bassani tips (LOUD!)
Slotted rotors up front, drilled in rear
Black 2003 Style 18" Cobra Rims
Rear seat delete (previous owner did this, might put one back eventually)
Corbeau TRS Microsuede seats
Eclipse head unit and speakers and iPod adapter
JL Audio 13" sub
TMA amps
Brenspeed 91 Tune
HD clutch
Aluminum Driveshaft
MM Panhard Bar
MM Torque Arm
JL Audio 13" sub
TMA amps
