Showcase cover image for tj25n1's 2003 ford mustang gt
General Information
Year
2003
Make
ford
Model
mustang gt
281ci block Bored .020 now a 291ci
8 bolt Forged Crank
MMR Forged Pistons
Manely Forged H Beam Rods
PI heads Ported and Polished
Comp Cams custom grind for boost and nitrous
Comp cam bee hive springs
Ford Racing Cobra Oil Pump
Cloyes Timing Set
Felpro Gaskets
TKO600 Transmission
Centerforce DFX Clutch
Steeda Shifter
Kennebell supercharger 2.1 (17psi)
Zex Wet Kit (100shot)
60lb Injectors
Modified stg2 FPDM
Dual Ford GT 500 Pumps
KenneBell Boost a Pump
-8 Poly supply Line -6 Poly Return Line
Div-X Fuel Hat
Fore fuel Rails
PPRV Delete
2-¾" Pulley
7.5" IW Crank pulley
Steeda Cold Air Intake - 10" Filter
BBK Headers
Bassani X Pipe (Cats)
Bassani Catback
90mm MAF
Mafia Adapter
BBK Throttle body
3.73 FRPP Gears
3.5” Ford Racing driveshaft seamless
Auburn Pro series carrier
Yukon 4340 Chromoly 28 spline axles
New Timken bearings
Zex Window Switch
Zex Bottle Heater
Zex Purge
Ford B Springs
Edelbrock Adjustable Upper/Lower Control Arms
Rear Sway Bar
SOS Pod (Boost/Fuel PSI gauges)
Wideband 02 sensor
Cobra R AFS wheels/Nitto Tires (275 fronts, 315 rears)
3.5" Cowl Hood
Tuned by Eric Brooks with Brooks speed.
Runs on E85
Thanks for looking
Gallery
Comments
