General Information
Year
1999
Make
Ford
Model
Mustang
Audio System: $5,829.00
Head Unit
Alpine iDA-X305............$350.00
Amps
Polk Audio: PA500.4......$429.99
Polk Audio: PA1200.1....$649.99
Speakers
Rockford Fosgate 6x8 T1682........$249.99
Polk Audio 3.5............................$59.99
Rockford Fosgate 6x8 T1682C......$159.99
Rockford Fosgate 5.25 T152s.......$349.99
Rockford Fosgate 12 T112D4........$449.99
Cables:
StreetWires Power, Speaker, Patch..........$1,000.00
Sound Damping:
Dynamat Xtreme......................$1,250.00
_______________________________________________________________
Suspension: $3,560.00
Energy Suspension Motor Mounts $145.99
Energy Suspension MASTER SET $205.99
Hotchkis Delta Camber/Caster Plates $239.99
Eibach Front Sportline Lowering Springs $229.99
Eibach Anti-Roll Bar Kit $319.99
Koni Rear Sport Series Dampers $257.99
Koni Front Sport Series Dampers $383.99
Koni Rear Quad Shocks $240.99
Steeda X2 Balljoint $136.99
Steeda Bumpsteer Kits $167.95
Kenne Brown Extreme Matrix Subframe System $359.00
Steeda Upper Control Arms $241.45
maximum motorsports Heavy Duty Rear Lower Control Arms $389.95
H&R Rear H&R Mustang Race Springs $239.00
Body & Repair: $11,278.76
Saleen Body Kit OEM $1,499.99
Saleen OEM Sail Panels $399.00
Door Logos $59.98
Door Strips $99.99
Trunk Badge $49.95
Winshield Banner $29.99
Cervini '95 COBRA R STYLE FIBERGLASS HOOD, 3.5" RISE $558.99
99-04 FENDER, FRONT, RH, FORD ORIGINAL $194.99
99-04 FENDER, FRONT, LH, FORD ORIGINAL $194.99
99-04 SPLASH SHIELD, INNER, FENDER, RH, REPRODUCTION $29.99
99-04 SPLASH SHIELD, INNER, FENDER, LH, REPRODUCTION $39.99
94-04 HARDWARE KIT, SPLASH SHIELD. $16.99
99-04 RADIATOR SUPPORT $109.99
99-04 GRILLE ASSEMBLY, GT/V6 $99.99
94-04 MUSTANG RADIATOR AIR DEFLECTOR $19.99
94-04 MUSTANG RADIATOR AIR DEFLECTOR HARDWARE KIT $3.99
99 MUSTANG RH 35TH ANNIVERSARY FENDER EMBLEM $27.99
99 MUSTANG LH 35TH ANNIVERSARY FENDER EMBLEM $27.99
Projector Headlights $394.00
Paint $7,400.00
SCCA Championship Wreath Decal 99-00 $19.98
Engine Drivetrain: $3,010.00
86mm Mass Air Meter $249.99
Fuel Rail PSI Gauge $59.99
78mm Throttle Intake $289.99
Cold Air Intake System $209.99
3 Piece SFI Pulley Kit - 4.6L $279.99
Long Tube Headers - Chrome $349.99
GP Catted X Pipes Mustang $325.00
Header Bolts $43.99
MMR Street/Strip 7 Qrt. Oil pan $229.99
Hurst Billet/Plus Shifter $239.99
Blaster Coil-on-Plugs $361.99
Clutch Kit, Dual Friction 11 in. Diameter Disc $369.95
Misc: $3,393.00
Saleen Floor Mats $159.95
79-09 MUSTANG BLACK 8" SHORTY ANTENNA MAST $17.99
Door Panel inserts $39.99
Trunk Panel $199.99
DEFROST SIDE DASH VENTS $23.50
FORD MUSTANG MIRROR PAIR LH & RH $68.95
FRONT WINDOW MOTOR SET 1994-2004 $86.45
HAVC Panel From 2004 Mustang $30.15
Cobra 1999 Speed o Cluster $68.74
Vapor Canister Purge Valve $83.50
Vapor Canister $49.99
Carlite Front Winshield $262.76
Chrome Deep Dish Cobra R Wheels 18x9 18x10 $779.00
Toyo Tires Proxes T1R 295/35ZR18 103Y (quantity of 2) $529.52
Toyo Tires Proxes T1R 255/40ZR18 99Y (quantity of 2) $438.38
98-04 MUSTANG THROTTLE CABLE $41.99
Power Steering Hose $73.37
(A/C) LIQUID LINE $84.99
Idle Air Control Valve $148.99
Air Charge Temperature Sensor $35.99
Throttle Position Sensor $56.99
Coolant Temperature Sensor/Sender $11.99
Trunk Lift Support (quantity of 2) $49.98
35th anniversary bezel $45.00
AIR BOX RUBBER BOTTOM MOUNTS $4.99
Blower Install: $6,600.00
Cobra Dual Fuel Pumps: $250.00
Cobra Tank: $299.99
SCT Livewire: $509.00
SCT Pro Racer: $299.00
Intercoolor Expansion Tank $99.99
Stock Eaton M112 $590.00
Tork Tech Terminator kit $2,165.00
Lightning threaded iat sensor $18.99
03-04 cobra throttle cable $48.99
03-04 cobra cruise control cable $30.99
03-04 cobra throttle & cruise cable bracket $30.99
90mm Mass air meter $79.99
42 lbs flow matched injectors (On 3 Performance LLC) $299.00
JLT true cold air CAI $197.95
AFCO Dual Pass Heat Exchanger $309.95
Meziere Intercooler pump & Fittings $195.95
Meziere Intercooler Fittings $39.90
Throttlebody and elbow *
Intake Plenum Elbow *
Throttle Position Sensor *
Idle Air Control Valve *
EGR DELETE PLATE $7.99
Cobra Throttle Body & Plenum $380.00
EGR Block Off Plate $19.99
Spark Plugs $28.00
1999-2004 FORD MUSTANG 4.6 LITER FUEL RAIL SOHC $45.00
Steggy stage 6 port $665.00
Head Unit
Amps
Speakers
Cables:
Sound Damping:
Door Logos $59.98
Door Strips $99.99
Trunk Badge $49.95
Paint $7,400.00
Header Bolts $43.99
Misc: $3,393.00
Trunk Panel $199.99
Cobra Tank: $299.99
Spark Plugs $28.00
