General Information
Year
2003
Make
Saleen
Model
s281
POWERTRAIN/DRIVETRAIN/EXHAUST
_______________________________________________________________
Saleen S281 4.6 2V
03' Cobra iron block honed .014 over
Cobra forged crank
Manley forged rods (arp rod bolts)
Diamond racing forged aluminum pistons w/ valve relief (19cc dish)
Federal Mougal rod and main bearings
MHS Stock Mod cylinder heads
Palacoy .600" lift valve springs
bronze valve guides
Viton valve seals
bowl port short-side intake radius
5 angle valve job
intake valve modified for more ptv clearance
Houston Performance 292s cams
60# Siemens Deka Fuel Injectors
SVT Cobra Dual Fuel Pumps
KB 40amp Boost-a-pump
FORE Precision Works Fuel Rails
D1SC Procharger w/ 3.4" pulley
AFM PowerPipe
3 Core front mount intercooler
Stock MAF with MAFia
Accufab 75mm Throttle body & Plenum w/ egr delete
Saleen Max Grip Differential
FRPP 3.73 Gears
Moser 28 Spline Forged Axles
FRPP Aluminum Drive Shaft
Ram HD Clutch
SFI Steel flywheel
Bassani Off Road X-Pipe
Magnaflow Cat-Back (American Thunder 40's Flowmasters welded in)
AIR MANAGEMENT DESIGN
Saleen design urethane front fascia
Saleen design urethane side skirts
Saleen design urethane rear fascia
Saleen louvered side scoops
Saleen S281 rear wing
Saleen "C" pillars
Saleen louvered hood scoop
Mach 1 grille delete
SUSPENSION
Saleen variable rate front and rear springs
Saleen front struts (N2) and bushings
Saleen rear shocks (N2)
Saleen front sway bar and pivot bushings
Maximum Motorsports Full Length Subframe Connectors (welded in)
Maximum Motorsports HD Lower Control Arms
Cobra 13" Front brakes
Saleen five spoke alloy wheels 18" x 9 " front and rear
STYLING & INTERIOR
Saleen leather sport seats
Saleen 200 MPH speedometer with white faced gauges
Saleen performance driving pedals
Saleen S281 graphics and identification
Saleen windshield graphic
Saleen fender badge
Saleen serialized engine bay plaque(#244)
Saleen serialized bumper number(#244)
Saleen serialized console plaque(#244)
Saleen championship wreaths
Saleen custom carpet door panels
Saleen custom floor mats
FRPP Brushed Aluminum/Leather Shift Knob
Pro 5.0 Short Throw Shifter
Dual Gauge Pod A-Pillar
Autometer Cobalt Boost Gauge
Autometer Cobalt Fuel Pressure Gauge
DM-200 OBDII Gauge(Inside rear view mirror)
HID 8000k Head Lights
The tuning was performed at Houston Performance where i had an SCT 4 bank chip installed.
Saleen S281 4.6 2V
Cobra forged crank
bronze valve guides
Viton valve seals
5 angle valve job
AFM PowerPipe
FRPP 3.73 Gears
Ram HD Clutch
SFI Steel flywheel
Saleen "C" pillars
SUSPENSION
STYLING & INTERIOR
Saleen fender badge
