General Information
Year
2002
Make
Ford
Model
Mustang GT Convertible
Color
Mineral Grey
Packages
Premium Deluxe
History
Bought it 12/11 in Houston with 53K on it.
2002 Ford Mustang GT Convertible (Mineral Grey)
Modifications
Drivetrain
BBK CAI and MAF (calibrated for the #24 injectors); Trick Flow 75mm t/b and plenum; PP Typhoon manifold; Accel coil packs; BBK long tubes and o/r x-pipe (w/MIL eliminators); Borla Type-S cat-back; Prothane motor mounts.
Interior
Corbeau CR1 seats; Alpine sound system w/Infinity speakers and Alpine Type R 10" subs; new carpet and "Powered by Ford" floor mats; rear seat delete.
Audio
Exedy lightweight billet flywheel; Centerforce dual friction clutch; Quick Time bellhousing; T56 Magnum trans with 2.95 1st; FRPP aluminum driveshaft; FRPP 31 Spline Heavy Duty Rear Axle Kit with carbon disc diff, 4.10 gears and Moser axles.
Suspension
Eibach Pro-Kit lowering springs; MM caster/camber plates; SVE tubular rear control arms; KYB AGX adjustable struts, shocks and quads; Prothane front sway bar end links.
Wheel and Tire
SVE Antracite Bullitt wheels (9X17 and 10.5X17) and Nitto 555 tires (275's in front and 315's in back); Powerstop drilled/slotted rotors, calipers and Z26 ceramic pads.
