General Information
Year
1987
Make
Ford
Model
Mustang LX
Bought it in Jan. 2008 with 55,000 original miles. There were 1,371 Oxford White paint hatchback mustangs built in '87. Mods: 3.73 gears with a limited slip. LPW stud girdle. BBK shorty headers. Flowtech starter tubes, Dynomax super turbo mufflers, and Flowmaster tailpipes. UPR catted x-pipe. Summit driveshaft safety loop. Mallory ignition coil. Biondo line locks. Accel TFI module. Jacobs Electronics pro fit ceramic plug wires. Jacob Electronics analog rev limiter. Speedhut digitally programmable shift light. Euro style taillights. Trick Flow aluminum underdrive pullies. Prothane poly motor mounts. Energy Suspension poly trans mount. Redline Tuning hood strut kit. Northern Racing aluminum radiator. Flex-A-Lite electric fan. MAC Performance fenderwell intake. Steeda drag springs. BBK spring isolators. Tokico 5-way adjustable shocks and struts. Steeda Tri-ax short throw shifter. '04 mustang gt front seats. '91 mustang "pony" wheels. Kenwood stereo. Ford Racing aluminum driveshaft. Ford Racing radiator hose kit. UPR tubular upper trailing arms, Jegster "lift Bar" lower trailing arms, Jegster upper control arm relocation brackets, Maximum Motorsports strut tower brace, k-member brace and full-length subframe connectors. Competition Engineering torque box plates, UMI jacking rails, UPR battle boxes. Scott Drake center caps with cobra inserts. Hurst T-Handle shifter knob with 12volt switch. Ford Racing double hook clutch quadrant and Ford Racing topside clutch cable adjuster and adjustable clutch cable. Cooper Zeon ZPT tires, 245/50/16 rear, 225/50/16 front. A set of 95 cobra R replica 17x9 wheels with 26/11.5/17 M/T ET Streets on them and a set of 22 year old Centerline "dinnerplate" 15x3.5 wheels with 26/4.5/15 on them for the track.Toploader 4speed, Zoom kevlar clutch, Ram billet steel flywheel. Lakewood safety bellhousing, Hurst super street shifter and install kit, and Hurst super boot
going to do a typical h/c/i swap.
fastest run to date is a 14.11sec. Best 60ft time: 1.91sec
2007 ROUSH LC Mustang:
My dad bought it brand new in February 2007. There were 56 ROUSH LC "low content" Mustangs built in 07 and only 10 of those came with Tungsten Gray, Gray cloth interior, 5speeds. Mods: FRPP 4.10 gears, Superior Axle chromoly axles, and a Ford Racing stud girdle. Detroit Locker. Carriage House Engineering upper and lower trailing arm relocation brackets. Carriage House Engineering engine k-member brace with torque limiters. Granatelli ploy motor mounts. Granatelli adjustable upper trailing arm. UPR tubular lower trailing arms. Steeda short throw shifter. RAM flywheel. Zoom throwout bearing. Centerforce dual friction clutch. Speedhut digitally programmable shift light. Steeda underdrive pullies. JBA cat4ward headers. BBK throttle body. Roush cold air intake. Diablosport tuner. Ford Racing mufflers. Summit driveshaft safety loop. BMR panhard bar relocation bracket. BMR strut tower brace. BMR subframe connecters. QA1 12-way adjustable rear shocks. Tokico spec-d front struts. Classic Design Concepts chin spoiler and sequential tailight kit. Hurst T-Handle shifter knob with 12volt switch. One piece aluminum driveshaft. Grillcraft MX Series grille. Saleen headlight spliters. Biondo Line Locks. MSD Two-Step. MSD coil packs. When we take it to the track we have a set of "S" style 17x9 wheels with 26x11.5x17 M/T ET STREETS for the rear and Centerline Qualifier 17x4 with M&H Racemaster 26/4.5/17 tires in the front. Best of all its got no supercharger but everywhere my dad goes in the car someone always comes up and asks him if it has a supercharger.
We're debating on building a mean all motor 3-valve stroker or put twin turbos on it.
Fastest run to date is a 13.40sec. Best 60ft time: 1.74sec pulling the front tires 3inches off the ground
1982 Mustang LX notchback:
My brother bought the car in march 2009. All stock. Its got a 200ci inline 6, C5 automatic, and 7.5 rearend. The plan for it is to leave the paint and interior alone and put in an 8.8 rearend, a C4 automatic with an 8inch converter and a 2.3 turbo motor from an '86 turbocoupe with an aftermarket head, cam, and intake, and a stroker kit and do the same suspension set up as my car except use Strange 10way adjustable shocks and leave the stock springs.
