General Information
Year
2000
Make
Ford
Model
Mustang
BMR adjustable lower control arms with sphericle bearings on axle side and polyurethane on car side.
Torque box reinforcements
Full length subframe connectors welded in
H&N 2in lowering springs
Tokiko Shocks
01 saleen rearend with 4.10 gear set
green stuff EBC pads
Mach rear spoiler
Hood pins with removed hood latch
Tri-ax Short throw shifter
BBK catless x pipe
Flowmaster 40 series cat back with polished tips
ZEX wet kit with dual purge bottle mounted in trunk
Angel eye halo head lights with LED’s
Aftermarket “euro” mirrors with turn signals inside
Aftermarket stereo including subs and aftermarket headunit
Custom cold air intake
80mm MAF from mach
Bullit intake
30lb accell injectors
Brand new alternator
Electric meziere water pump on toggle
Anderson motorsport cams stage 5 N/A
Teskid aluminum block
manley rods and pistons
11:1 compression
Port and polish PI heads
Walsh Motor Sport custom dyno tune
Full AC delete
Aftermarket 3 pod on a pillar (narrow band (dico ball) nitrous pressure, fuel pressure at rail)
Custom paint (2007 lamborgini gun metal)
Tokiko Shocks
Mach rear spoiler
BBK catless x pipe
80mm MAF from mach
Bullit intake
11:1 compression
Full AC delete
