General Information
Year
2002
Make
Ford
Model
Mustang GT
-C&L plenum (removed after KB install)
-BBK 75mm TB (removed after KB install)
-JLT Fenderwell CAI
-Mach 1 chin spoiler/grille delete
-red calipers
-clear corner headlight housings
-Eibach Pro kit
-Magnaflow magnapacks (removed for MACs)
-bunch of little billet interior goodies & custom lights
-255/35/17 Nitto 555's (up front)
-Maximum Motorsports caster/camber plates
-SCT SF3 with Tricktuners tune
-Laurel mountain mustang full length sub frame connectors with torque box reinforcement plates
-centerforce dual friction clutch
-ford racing throw out bearing
-MGW short throw
-Steeda quadrant and firewall adjuster
-Bullitt pedal covers
-3.73's
-carbon fiber t-lok clutches
-richmond diff. install kit
-Apexcone 6k HIDs dual beam
-polyeurethane (sp?) motor mounts
-BBK longtube headers
-percy's header gaskets
-stage 8 header bolts
-Kenne Bell 1.7L intercooled
-Accufab 75mm TB
-39 lb. injectors
-BBK O/R H
-90mm MAF
-03/04 Cobra tank & twin pumps
-20 amp Boost-a-pump
-Autometer cobalt boost, oil pres., wideband a/f
-glow shift tripple A-pillar pod
- 03/04 cobra heat exchanger
-Sony xplod cdx-gt640ui head unit
-Chrome DD cobra's
-Zone 5 performance modified FPDM
-Flowtech Flowtubes
-Stainless MAC flowpaths with Magnaflow tips and over axle pipes
-D'Augostino Racing KB FRPS disc
-VT/CMS stage 3 Blower cams
-MHS Viton valve seals
-Comp Cams High Load valve springs
-JLT Fenderwell CAI
-red calipers
-Eibach Pro kit
-MGW short throw
-3.73's
-Accufab 75mm TB
-39 lb. injectors
-BBK O/R H
-90mm MAF
-Chrome DD cobra's
-Flowtech Flowtubes
