General Information
Year
99
Make
SVT
Model
Cobra
Engine:
Manley rods with ARP 2000 fasteners
Custom Diamond .040 Flat Top Pistons
Clevite H series rod and main bearings
Total Seal Steel rings
Eagle Crank
ARP hardware throughout
Mod Camponents timing gears
Comp Cams Xtreme XE-R Series, XE270AH-114
Manley valve springs
Bronze valve guides
Ported/Polished intake manifold with port matched TB plenum
Ported 9 thread C heads w/valve job
8 quart Moroso oil pan
ACCUFAB TB
JLT cold air
Mac L/T
Mac Prochamber
Mac Catback
Teksid Bored .040 over
Power adder:
N/A for the time being
Drivetrain:
MGW orange handle shifter
Ford Racing 5 speed shift knob
Rebuilt (Promotion) T-45
Spec stage 2 clutch
Spec Steel flywheel
Ford Racing TOB
FRPP aluminum drive shaft
Solid rear axle
4.10 gears
31 spline moser axles
31 spline Trutrac
Suspension:
MM caster camber plates
Camber bolt
Tokico HP's front and rear
H&R SS front and rear w/o ISO's
Eibach rear sway bar
Steeda bumpsteer kit
Steeda clutch quadrant with firewall adjuster and ford clutch cable
CHE double adjustable rear upper control arms
CHE rear lower control arms
Prothane motor mounts, transmission mount, steering rack mount
Racecraft tubular K
Racecraft front spring mounts
Termi A arms
Baer front and rear cross drilled and slotted rotors
Electronics:
Viper 791xv 2 way remote start alarm with remote start disabled
Pioneer AVIC-D3 with bluetooth and ipod adapter
Infinity Kappa components up front
Infinity Kappa rear
Infinity 4 channel amp
Rockford Mono Amp
2 JL audio W3V2
Raptor Shift light
PLX DM-5 wideband
Autometer Electric Fuel pressure gauge
Autometer Electric Oil Pressure gauge
Visual:
17x9 Simmons FR17 3 piece wheels with stepped lip
17x11 Simmons FR17 3 piece wheels with stepped lip
Nitto NT555 275 up front and 315 in the rear
Shaved front plate holes
Shaved spoiler holes
Termi Chin
01 smoked head lights
8" shorty antenna
Eagle Crank
Bronze valve guides
ACCUFAB TB
JLT cold air
Mac L/T
Mac Prochamber
Mac Catback
Power adder:
Drivetrain:
Spec stage 2 clutch
Spec Steel flywheel
Ford Racing TOB
Solid rear axle
4.10 gears
31 spline Trutrac
Suspension:
Camber bolt
Racecraft tubular K
Termi A arms
Electronics:
Infinity Kappa rear
Rockford Mono Amp
2 JL audio W3V2
Raptor Shift light
PLX DM-5 wideband
Visual:
Termi Chin
8" shorty antenna
