General Information
Year
1998
Make
Mustang
Model
GT
-Griggs-
- K-member
- Tubular control arms
- Sub-frame connector
- Strut tower brace
- Torque arm
- Panhard bar
- Lower Control arm
- Caster Camber plates
-Others-
- Rack and pinion redone with aluminum bushings
- NASCAR style rear spoiler
- Koni DA coilovers front and rear
- Cobra brakes up front with Brembo 13" rotors
- Stainless steer brake lines
- Brake proportioning valve with stock gutted
- 5-speed swap with B&M Ripper short throw
- Aluminum flywheel
- MM quadrant and firewall adjuster
- Off-road x-pipe with Flow 40's
- SCT Tune from BAMA Performance tune
- NGK TR6 spark plugs
- UDP kit
- K-member
- Strut tower brace
- Torque arm
- Panhard bar
- Lower Control arm
-Others-
- Aluminum flywheel
- UDP kit
