General Information
Year
2002
Make
Ford
Model
Mustang GT
ENGINE:
- STOCK 4.6L ALUMINUM 01 COBRA SHORT BLOCK (-75LBS OVER IRON BLOCK, HAS -2.3CC DISH PISTONS WHICH RAISE CR TO 11.7
- TFS 44CC HEADS PORTED BY FOX LAKE 263/214 CFM
- VT STAGE II CAMS
- AFM 4" POWER PIPE CUT IN HALF WITH A 95MM LIGHTNING MAF
- BBK 78MM THROTTLE BODY/PLENUM COMBO
- BBK UNDERDRIVE PULLEYS
- KOOKS LONG TUBE HEADDERS WITH MATCHING X-PIPE
- SVT 30LB INJECTORS
- CUSTOM SCT DYNO TUNE (355RWHP/348RWTQ)
- MEIZURE ELECTRIC WATER PUMP
- 1/2IN PHANOLIC INTAKE SPACER (HAND PORT MATCHED)
- 2.5IN MAGNAFLOW CATBACK
- 180 DEG POWER STAT
- SVT FOCUS 255LPH FUEL PUMP (ZX3 GREEN TOP)
- EGR DELETE
DRIVETRAIN:
- AODE 4R70W TRANSMISSION LEVEL II REBUILD
- TUBULAR FRONT SUSPENSION W/STRANGE COIL OVERS (SAVES -90LBS)
- TRANSGO SHIFT KIT STAGE III
- MOTIVE 410 GEARS
- TIGHT 4,000 RE-STALLED PI TORQUE CONVERTER
- 04 COBRA BRAKES UP FRONT
- HAWK PERFORMANCE BRAKE PADS
- FRPP ALUMINUM DRIVE SHAFT (SAVES 20 LBS W/O STOCK BALLANCER)
- STEEDA ALUMINUM LCA's, and UCA's (SAVES 25LBS WHEN REMOVE QUAD SHOCKS)
- TA REAR GIRLDLE
- POLY MOTOR/ TRANS MOUNTS
- ADJUSTABLE REAR COIL OVERS
- REMOVED FRONT SWAY BAR. SAVES 25LBS
- STEEDA REAR COIL OVERS
- REMOVED FROM AND REAR BUMPER SUPPORTS -60LBS
- STEEDA FULL LENGTH SUBS
INTERIOR:
- CUSTOM PAINTED INSERTS / CUSTOM WINDOW TINT
- YMR REAR SEAT DELETE KIT (SAVES 45 LBS)
- X2C FRONT RACING SEATS (SAVES 110LBS)
- STEEDA BILLET ACCESSORIES
EXTERIOR:
- EAGLE 17X9 ALUMINUM RIMS - MACH 1 CHIN SPOILER
- MT DR'S (27540R17 OUT BACK) - MACH 1 GRILL DELETE
- FUTURA (24540R17 UP FRONT) - FUNCTIONAL HOOD SCOOP
FUTURE MODS:
- COBRA R HOOD (SAVES 20 LBS)
- TELESTARS ALL AROUND (-70LBS)
Comments
There are no comments to display.
