General Information
Year
2004
Make
ford
Model
mustang
Engine:
Boss big bore block
Full forged setup
Kellogg stroker crank
Manley 23CC dish pistons
Manley rods w/ ARP2000 bolts
Custom ported Trickflow44 heads with oversized valves
(heads went to T.E.A. for all the goodies)
Custom ground Bullet cams
ARP 2000 Head studs
P51 custom ported intake
75 mm accufab tb
Inovators west 10% OD
GI JOE 8 Rib kit
Transmission:
FB performance 4STB-E
HD input drum
HD Direct drum Assembly
Electronic O/D
Electronic L/U
Full manual VB
Trans brake
!0" full race multi disc converter (4000 stall)
Wide ratio gear set
Deep pan
Hurst Quarter stick pistol grip
Procharger D1SC
3 core IC
3.4 pulley
Procharger Big Red BOV
Anderson power pipe
Snow performance meth inj.
Fuel system:
cobra tank
Fore fuel hat w/ 2 405 pumps
Fore innovations FPR
Fore relay block
Wire upgrade
-8 line feed and return
cpr fuel rail
80 lb. Bosch injectors
ford racing 3.73 gears
ford racing lca
steeda adj. uca
mm full length sfc
mm caster camber plates
msd shift light
sos dual gauge pods
nv boost gauge
nv wide band
American Racing 13/4 headers
Amaerican Racing catted X pipe
JBA stainless cat back system
wot box
Boss big bore block
Full forged setup
ARP 2000 Head studs
75 mm accufab tb
GI JOE 8 Rib kit
Transmission:
HD input drum
Electronic O/D
Electronic L/U
Full manual VB
Trans brake
Wide ratio gear set
Deep pan
Procharger D1SC
3 core IC
3.4 pulley
Anderson power pipe
Fuel system:
cobra tank
Fore relay block
Wire upgrade
cpr fuel rail
ford racing lca
steeda adj. uca
mm full length sfc
msd shift light
sos dual gauge pods
nv boost gauge
nv wide band
wot box
