1 - 2 of 2 Posts
Hey guys I have a 00' new edge that is finally going to be turbocharged 2v with a hellion turbo kit 67mm at the end of the month. With that being said I wanted to get your opnion as to what is the best brand of gauges I should buy? AM and LMR have so many options to choose from. Also typically since I am going turbo what are the essential gauges to buy in order to display my cars performance? One last thing I also would like to modernize my dash and replace all of the speedometer gauges etc however I haven't see one that allows for the check engine light and other codes to show if needed. Thanks in advance for your help guys!
Super Moderator
You need an AFR gauge first and foremost. I have a PLX wideband it has the muti gauge setup where you can have all your gauges in one. with the toggle of a switch you cans witch between oil pressure, AFR, votage ETC.
With that being said I still have a boost gauge, Volt gauge, oil pressure gauge, trans temp gauge coolant temp gauge and the AFR because i like just to have a bunch of ****ing gauges hanging all over the place in the car Lol.
1 - 2 of 2 Posts
