1 - 3 of 3 Posts
I noticed the 2000 vs 2001 v6's called for diff coil packs. Also, I just purchased some plug wires for an 01-04 (found out by part number) but I have a 2000. My main question is what is the major difference in the 2 and will I be able to use the plug wires with my coil pack? I noticed the plug wires have boots instead of the clips that my OEM plugs have. Didn't know if that was just because they were upgrades. Here's the plug wires I got:
Not A Regular Member
The connectors on the coil packs for the 01-04s are longer than the ones on the 99-00s. I've got a 2000 as well so I know the clips you're talking about and I don't think the wires will work. If I was you, I'd just go pop your hood, pull one of the wires off the coil pack, and see if the new wires will connect or if the boot is going to be a problem (which I assume it's going to be).
1 - 3 of 3 Posts
