1 - 3 of 3 Posts
hey i'm having some problems with my electric windows. my driver side window won't roll up or down. the button works and i know the motor is working because i can push the button and the window will move but only when i push or pull on the window. Any ideas?
The motor is over turned.
Take the door panel off and hit the motor with your fist or a rubber mallet. It should come back to life. Happened to me twice now.
thanks for the response, but as i messed with the window i found out what the problem was. The gear plate (the piece with the teeth that the motor drives) on the regulator broke off the regulator from the welds.
1 - 3 of 3 Posts
