1 - 2 of 2 Posts
Just wondering if anyone could help me out, im rebuilding my 03 4.6 motor after spinning a bearing on crank and now crank is shot.. so i have to get new internals and wanted to go with stroker kit ... i have read alot about them and have a few questions.... for 1 can i use a 5.0l stroker kit with my stock aluminum heads i have got my motor apart and have ported and polished the heads and also have a set of comp cams for it just wondering will it be a cleareance issue with my valves or will my stock heads even hold up
k
Post In the 99-04 section for immediate answers. I believe you can use your pi heads. Not sure what your compression ratio would be though. It depends on what piston the stroke kit has
1 - 2 of 2 Posts
