1 - 20 of 31 Posts
I just recently bought my dream car a 03 cobra low miles and up grades already installed the guy i bought the car from gave me a bunch of recepts of what was installed also some dyno sheets the car is suppose to be making 604 at the wheel @ 17 psi it has a whipple charger, but im running a 3.50 pulley and i believe the crank pulley is stock there fore i should only be running around 13 psi i believe, but i cant tell what size the pulley on the crank is therefore im not real sure of how much boost im running i have a factory boost guage, is there a mark somehwere on the crank pulley so i can tell how big it is are someway to measure it
N/A 4v Guru
Boost gauges are pretty cheap. Good investment anyway on a modded boosted car
yea boost guages are pretty cheap and i plan on getting one but they dont tell me how big my lower pulley is
See if you can get a pic of it. 17 is definately possible on a stock lower Whipple car. What altitude are you at? No location in sig or panel.
im in middle georgia i will try to get a pick tommorow i keep the car at my uncles shop,
well i took some pics but i cant figure out how to get it on here
Upload them to photobucket then copy the direct link into the image box on here.
Discussion Starter #15
ok i finally got it to work sorry for all the blank spaces
Here I'll help you out.
Discussion Starter #19
thanks man i dont usually mess with photobucket
No problem, use that box that's circled though click in it and then come here go to the reply box and insert image and then paste that into the box and there you go it should work then. I wish I could be of more help with the supercharger but I unfortunately know nothing about them.
1 - 20 of 31 Posts
