1 - 12 of 12 Posts
did yours not come with fog lamps....bc my v6 i had (2000 v6) had a hookup only on the drivers side, but no lamps and such....did someone add lamps and not put in the wiring? just a thought.
Doc
you would have to get into the harness and find the correct wires to plug into if you want to keep it factory looking.
if not you could just run an after market set up.
hot wire
ground
acc
toggle.
EDIT.. you have a v6? I thought GT because of the user name.. that's why you don't have a wire.
you need the harness from ford.
it had fog lamps my drive side has it but the car has damage in the front minor and it had the fog lamp but broken i abught new one then i go to plug in and the whole plug and wires are not there and i searched
Doc
so you DO have a GT.. ok
yea like I said then man. 2 options.. try and splice into the factory harness or do what the 6ers do and run new wires to a toggle.. I am sure you can make the factory button a toggle.
1 - 12 of 12 Posts
