1 - 1 of 1 Posts
FEATURES
Smoked Lenses w/ White Diffusers
Built-In Sequential Turn Signals
60 Bright, Long-Lasting LEDs
Provides Added Safety
DOT Compliance # QR1200176
2-Year Full Warranty
Sold as a Pair
Fits All 2005 to 2009 Mustangs
DESCRIPTION
Modernized Styling. After having your Pony on the road for 7+ years, you might be craving a bit of visual modification. Swapping out your factory tail lights for a new, modernized style complete with bright, long-lasting LEDs will easily transform the rear of your 2005-2009 Mustang. Featuring a stealthy smoked lens with three white inner diffusers, this pair of Vector Tail Lights will stand out from the crowd and allow fellow commuters to easily see you. For added safety, these lights sequence when using turn signals or hazards and include three reflectors located along the bottom.
Turn Signal Sequentials. These Smoked Vector Tails are designed with a very popular component that not only looks awesome, but supplies an added bit of safety when out cruising. When the turn signals or hazard lights are activated, they will sequence from the center light out and repeat until switched off.
High Quality Construction. Crafted from high quality ABS plastic, each of these Vector Tail Lights feature a smoked outer lens, three white inner diffusers, black housings and 30 high intensity LEDs to provide brighter, longer lasting light. Rid your Pony of those weak incandescent bulbs and improve your driving experience with these sleek replacements.
Easy Installation. Assembled from state of the art electronic components, these Raxiom Vector Tail Lights utilize a simple plug-in connector that gets inserted into the stock wiring harness and the factory reverse bulb will be reused. This allows for a straight forward installation that lets you get back on the road in no time.
DOT Compliant. Raxiom Vector Tail Lights will not only bring a fresh new look to your Mustang, but they also meet or exceed the strict guidelines set forth by the U.S. Department of Transportation (DOT). They are DOT compliant under compliance # QR1200176.
Full Warranty. Raxiom stands behind their products and backs these Smoked Vector Tail Lights with their Industry Leading 2-Year Full Warranty.
Application. This set of two Raxiom Smoked Vector Tail Lights with White Diffusers are specifically designed to fit all 2005 to 2009 Mustangs, including the V6, GT, Bullitt and Shelby GT500 models.
1 - 1 of 1 Posts
