1 - 14 of 14 Posts
Just wondering if anyone has put seats from a 05-2011 to a fox. If so, what has to be done to get this to work. I want to put the front and back seats in, if possible. Thanks for the help.
I have seen seats from an 08 in a 83 hatchback, the way the guy talked there was not much to it. That was the front seats though and he still had not hooked up the power portion so they were not able to be adjusted at that time.
The rear seats could be a whole different animal though.
there was a thread on here a couple years ago. there was a guy that put cobra seats front and back into his car. i'm sure there is a way to get the backs in. on the fronts ,it's pretty easy. as far as hooking up power and everything else, i'm not sure. you have to put your fox seat tracks on the s197' seats.my seats are 05' v6 seats with no power, so i didnt have to worry about that. the s197 seat tracks are huge! i see no way to get them in without swaping the seat tracks. you'll need a drill, bit, and some hardware (nuts,bolts and washers).i had to cut some of the washers down on one side to get things even. youll see what i mean when you go to do it.
i had just seen that thread one sat morning before i went to the j/y, and sure as **** their was a rolled 05' there. i got the seats for $56. one of the best j/y finds i've ever had. they are lighter (w/fox tracks)and way way more comfy!
thanks alot i have the seats but the way it sounds, i think it may be better to try and find 6 cyc. seats. Thanks for all your help.
You might can find someone with a six cylinder car that wants the power seats and trade with them. The six cylinder cars probably already have the wiring in place so it would be plug and play for them.
94-04 frount seats are a direct bolt on yes. they still share the same floor pan and tracks.i think the backs are a few mods to fit,but doable. if you can find 05+ v6 seats. it's well worth the few nuts and bolts it takes to get them in. there are a few pics of mine here.
Come at me bro
I have 1994 or 1995 SN95 GT seats in mine. Just switched the frame on the bottom, and had to drill a few of the hole's bigger or elongate them. thats all.
you do sit up about a inch higher still.
there 10x's more comfy, but way heavy, and mine are ash grey, when I have porno red interior. so it looks ****, but the deal was right, and my oem seats where broke so bad, I had to wedge a box full of crap behind the seat just so it wouldn't gangster lean me into the backseat. lol
1 - 14 of 14 Posts
